Question about Tivoli Model Three Clock Radio
Tivoli model three clock problems
Help, my model three clock gives a beep then the clock hands begin to spin clockwise once I put in fresh battery. if I take out the battery this stops. the button to set time on the back does not respond or seem to advance the hands. the radio works fine, just the clock no longer responding to being able to set the time
    Problem Solver:
  • 5 Answers
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
Posted on Jun 04, 2009
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
How do I change to daylight saving time?
Your clock may have failed in a way that new batteries won't help.
Apr 04, 2015 | La Crosse Technology Atomic Wall Clock -...
Minute hand on atomic clock keeps moving
Take the battery out and put it back in the opposite direction. Wait 5 seconds. Put it back in the correct position. The minute hand will go around very fast and eventually come to a stop. This can take a couple days. That means it is waiting for a radio signal from Colorado. For a better signal, place the clock in a window that is facing Colorado. The minute hand will begin to spin very fast until it stops at the correct time. Again, this could take up to 2 days.
Sep 12, 2012 | Staples Round Atomic Wall Clock; 14
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Hands started spinning and won't stop. I replaced battery - still spinning
Remove the battery and replace with a new one. Just because.
Depress the tab on the back of the clock mechanism firmly (it pushes in a button beneath it) 22 times. While you're pressing the tab, the hands will begin to rotate. They will stop at 12 , 4 or 8 o'clock.
Place the clock in a window where it will be able to receive the radio signal.
Next morning the clock should have re-set to U.S. Pacific time. Press the on the clock mechanism that corresponds to your time zone and you should now have the correct time again.
May 24, 2009 | La Crosse Radio Controlled Atomic Clock
Agitator locks up
The agitator is supposed to turn freely one way then catch the other. in the top of the agitator there is three teeth that retract when you go counter clockwise and then when they go clockwise they come back out to bite on the inside of the agitator and then spin it. Those teeth are called DOGS. It is only when you can spin it freely both ways that you have a problem. There is nothing wrong with it. Congrats.
Jan 04, 2009 | Washing Machines
CLOCK NOT WORKING
Time to sell it on ebay!
Dec 17, 2008 | Tivoli Model Three Clock Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli Model Three Clock Radio Logo
546 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
