Question about MSI KT3 Ultra Motherboard
After hook up every thing and try to bring it for the first time but no power
  • 253 Answers
Try first to plug only the power supply into the board, do you get power? if so continue adding in order of importance until you find what is killing it, You can also test the power supply with a volt meter, set it to DC you can stick a paper clip in the Green and a Black hole in the motherboard input, and you should hear the fan on the power supply come on, then you can test the output, touch one probe end to the paperclip, and the other in another hole, ex.Red,Yellow,Purple,etc andcheck if the power supply is even good. just because an LED light on the Power supply comes on, doesnt mean it is functioning properly, you can also purchase a power supply tester for about $12 online.
Hope this helps, please give a good ratiing
Posted on May 12, 2009
  • 433 Answers
Check the switch on the back side of the power supply
Ematic esb112x
Try resetting the unit buy holding down the volume up and power button at the same time. It may work.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Audio Players & Recorders
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
What to do if machines timing becomes unaligned
First, what makes you thing that the hook is out of timing? If you cannot bring the bobbin thread up, it is an indication that your hook is out of timing. That can be caused by turning the hand wheel AWAY from you too many times; it can also be caused by getting a thread nest and forcibly turning the wheel. It involves loosening two Allen screws--usually 2.5 mm--on the other side of the gear that drives the hook, lowering the needle (#14 only) to its lowest point, and setting the hook so that it is EXACTLY 1/4" on the left of the needle, then tightening the screws again. If you have a vertical rotary hook, you also need to insure that your needle is in the middle of the basket. If you are determined to do this yourself, I would strongly recommend that you purchase the service manual for it; it's inexpensive and will help you a great deal. There are a number of YouTube videos on this, by the way.
Mar 04, 2014 | Singer 2517 Mechanical Sewing Machine
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
My whirlpool (KitchenAid) induction cooktop works sometimes and other times will. The power comes on but when I try to turn on the burner it beeps and starts flashing. There are no error codes showing
It is likely the computer in the control board I have seen this many times. It is really hard to get the factory to think this cause it's new and it is expensive. But you have checked the power so there is not much more that it could be
Aug 07, 2017 | KitchenAid 30" Electric Induction Cooktop...
Not powering on
When you power on the laptop press F8 function key several times to bring up the Menu and select Last known good configuration to see if your laptop boots up correctly.
Mar 24, 2012 | Computers & Internet
My kenwood kr v1074 reciever doesnt seem to do the job of my other reciever.....my sub is connected threw the red and black ports tried em all and my speaker just remains low volume even if i have it full...
You shouldn't hook things up and guess how they work.
BTW "KRV1074" doesn't bring up a valid link anywhere in the universe except your request.
Try finding the manual here...
http://www.kenwoodusa.com/ Use the Search box.
Mar 09, 2011 | Kenwood 107VR
The intergrated dvd is not working, it seems to be trying to take the disc in but doesnt catch it. the tv is about 10 months old.
Try an external DVD player and hook it up to the auxiliary input. If it works you can postpone getting the whole thing fixed because the DVD player maybe bad and you'll have to bring the whole thing into the repair shop.
Oct 25, 2010 | Televison & Video
I let my friend charge my ipod and i had a lock on it and she tried to many times to open now its says disabled wat to do??
Hold down the power button and the HOME at the same time this will then give you a chance to RE ENTER the passcode otherwise you going to need to hook it up to the orginal computer and the restore the thing. Other then that there are hacks out there but we are not allowed to by law to show you those so I hope you understand.
I hope this helps please do leave positve rantings and feedback, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2010 | Apple iPod touch
MSI KT3 Ultra Motherboard Logo
88 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
