Question about Acer Aspire 5050-3242 Notebook
I have acer aspire 5050 and the monitor will not show any screen i have no clue how to get it to come on the power light is on the charge battery light is on but no screen
2 Suggested Answers
Eddie333
  • 176 Answers
SOURCE: acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Posted on Jan 04, 2009
Acer aspire 5050 won't power up. have tried charger on different laptop and it works,
What you need to do is remove/replace "Bits" one at a time, ie: The hard drive, then the DVD, swap out the RAM... until it boots? or at least shows the initial screen. A laptop should display video with, just power adapter, RAM & NO Battery, HD, or DVD connected, although it obviously will not boot as such. If this still doesn't boot/show initial video after this you may find the Motherboard is faulty
Mar 08, 2010 | Acer Aspire 5050 Notebook
I have an Acer aspire 5050 and when i try to turn it on i hear the fans starting but nothing hapens on the screen. i tried to conect it to a pc monitor but it didn't work. I think there isn't any video...
hello gligor,
try this.
Turn Off Laptop
Remove the Power Adapter Pin
Remove the Battery and leave the Laptop Idle without Power n Battery for about 2-3 Hours
Fit the battery again and connect Power Adapter and try again
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
My computer will not boot up Acer 5050 all the lights com on but it never boots the screen stays black. it will not turn off unless you remove the battery.
If you have a VGA cable and a monitor, attempt to plug this into a monitor to verify that the laptop will not boot into your OS (Windows generally). If it does end up booting into your OS, then it sounds like your LCD has died or become unplugged inside the laptop.
Nov 25, 2009 | Acer Aspire 5050-3242 Notebook
Black screen / HD light steady and the fan keeps running
Ok, check your RAM, reseat or clean it with soft eraser, only its edge connector both side. Do this when unit is off and no other power source is connected to it even its battery.
Hope this help.
May 02, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Acer aspire 5050 can't turn it on
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
No signal prob...
some issue have to make sure
1) check battery charging indicate light on(yellow)
2) check AC adapter and DC jack connection if no bettery charging
3) check power on from battery or AC adapter that situation is same or not
4) take away HD DVD and change memory
5) plug extenal monitor
if no any thing show on the screen, you have to send to repair by the specialist.
Sep 27, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 5050 Power ON problems
that maybe the only problem. lets hope so.
Jul 29, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
