Question about Sony CPD G200 (White) 17" CRT Monitor
Horizontal Sync is wavy or jittery at all resolutions on 7 yr old G200
Had my G200 7 years..    In past few months verticle sync is stable. but horizontal sync is wavy at all resolutions and sync rates.
Is this a common problem?
If its just a capacitor going bad, I'd give a shot at changing it myself.
I know about high voltage danger.. I worked on monitors before.
 Thanks
Check data cabel pin13 H-sync
Posted on Nov 26, 2007
  • M.Anees Butt Nov 26, 2007
    also change B+ cap. 220uf/200v
After tv has been on for a while the picture goes in and out of multi colored verticle bars with horizontal rolling.
Thats problem have lost of harizontal sync.Try to adjust the horizontal hold until the picture back to normal.
Jul 05, 2011 | Televison & Video
Picture is wavy and jittery on some slides.
This could be a syncing issue with your computer and the projector. Try to set your display settings on your computer to a different resolution. i.e. 800x600 or 1024x768.
May 18, 2010 | Sanyo PLC-SP20N Multimedia Projector
Zenith b25a24z has a line in center of screen and i replace the verticle output ic and the problem remains can somebody help me?
was the line vertical or horizontal? if vertical check on the horizantal sync side if horizontal check vertical side also check for dry solder joint on the circuite.
Apr 07, 2010 | Zenith C27A24T 27" TV
Do these work as tv monitors as well?
jon_bailey, Some monitors do, and some monitors don't have that capability. If your unit has other types of baseband audio/video inputs and supports the old 525 line video signal it might work. Do you see any RCA type jacks on rear of monitor? RED, GREEN, BLUE for input of video with sync on blue? do you also see some inputs called H and V for the horizontal and verticle sync signals. You will need to contact ADVUEU TECH and try to download a .pdf file of the owners manual to find out all of the units capabilities. Bye for now. 12fixlouie
Dec 01, 2009 | Advueu Technology ADV178 17" Flat Panel...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Picture is jittery and voice is garbled with noise in background
Hello sneakymouse
It looks like you may have a servo or servo sync problem in either your recorder or your player. These are signs of such a problem. The circuitry that governs these function might be beginning to malfunction. Technically there is nothing that you can do in the way of repairing this unit you would have to have specialized equipment to trace down the source of the sync problem which is effecting your system. If you can not afford a repair shop right now I would suggest that you use your warranty and get it fixed. More than likely it is a problem with the servo IC or the sync oscillator circuitry.
I hope this helps,
Thank you,
Shuttle83
Jul 17, 2008 | Televison & Video
Trinitron
Probaly a solder connection on your chassis. look closely around the fly back, horizontal driver transformer and the verticle and horizontal yoke connections
Jan 16, 2008 | Televison & Video
Horizontal and Vertical Hold is malfuctioning and there is not manual adjustment
The fault is most likely in the sync amp section, or in the video detector section, or the area where the sync extraction is done. It is very common that some of the electrolytic capacitors in the mentioned areas become worn down with age.
An experienced TV service tech should be able to troubleshoot the sync areas, locate the faults, and replace the defective parts.
Jerry G.
Oct 10, 2007 | RCA 32V420T 32" TV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Sony CPD G200 (White) 17" CRT Monitor Logo
159 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
