Question about Samsung Refrigerators
Evaporator fan new but not working on samsung rs267lash
I own a Samsung refrigerator model # rs267lash. I have replaced the control board, condensor fan motor and evaporator motor, but the freezer evaporator motor is not working. Does anyone have a solution for me, or know if there is a relay that needs to be replaced?
  • alfonsov1703 May 12, 2009
    I bypassed the thermostat and still have same problem.
  • alfonsov1703 May 14, 2009
    I unplugged and replugged some of the connectors and fan started working. Thank you
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
  • 6 more comments
  • Wilson Bradley
    Wilson Bradley Jun 11, 2014
    Turns out I had to buy the whole coil system and tare it apart to just use the complete coil closure $200. Replaced the original one in the fridge. Definitely a Samsung defect. Make sure the symptom and model is the same before going through with it.
  • Wilson Bradley
    The symptom was the coils would OVER freeze and so the fan could not blow air over the coils for cold air.
  • Wilson Bradley Dec 04, 2014
    So, after a few years.. This was the fix for me and Im sure many others of you who have stumbled upon this. I will try and dig up more information and post.
    The Symptom is ; Defrosted the blower fan in fridge section (towards bottom) with blow dreyer to defrost overfrost on fan that blows the cold air from the coils. It refrezes 5 days later. I bought a coil system for under $200. Detached the coils from whole encasing and replaced the Samsung fridge coils. There is a thermal sensor inside or welded (If I remember) that is defective. Wow, Samsung could have replaced those for customers to save face on this defect.
    The coil system I bought was a parts replacement for the Samsung. I will try and find it and post.
    I found the Samsung repair manual PDF- send me an email if you want it, don't know where to host it for free.
    wilsonbradleyATgmailDOTcom
    and click helpful
  • 22 Answers
Check the defrost thermostat body and see if it has separated a little bit. I have seen the def thermo go bad and cause this problem about 6 times now.
Posted on May 12, 2009
  • Howie May 14, 2009
    The defrost thermo is only about 12.00. I really would try it. Remember, it takes a while for the the circuit to really kick in because of the delay time. I think 15 min or so if i remember. Other things to check, once you have a new def thermostat on it, and you know the evap coil is freezing cold with visible frost on it, put your volt ohm meter on the fan motor leads and check voltage. If you don't have 110-120, the nuetral line somewhere may be giving you a problem. Thats the white wire. Some connector along the way, may have built up a residue and not allowing current to flow. Also ck the connector pins on any of the connector blocks to make sure they haven't recessed back when the two are clipped together. The items on the circuit are, ( besides the compressor ) are the cold control, def.board, the evap fan motor, def. thermo.( bi-metal ) and condensor fan motor. I also see a sensor part # DA 32-10105r right beside of the def. thermo. but it lists as NLA ( no longer available ) as of 8/23/07. I don't know what that sensor is as it gives me no description or wiring diagram, it was 10.00. There is also a sensor at the top of the vent cover, but it doesn't say what it is for either. You may have it on the wiring diagram and be able to tell the ohm's values and check them. The info i have on this one is limited as i see many parts nla.
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Control panel displays 5y ef Model #FGHS2655PF5A
This error is a SY EF (system evaporator fault). The evaporator sensor is not reading enough air flow through the system. The problem could be the evaporator sensor or the evaporator motor.
It can also be linked to a faulty control board. To rule out a problem between the fan and the control board, you can check for 12V DC between the brown and the red wires. You can also check for voltage variations between the yellow and brown wires. (This voltage will depend on if the fan is on high or low speed.) If the voltages are good, replace the motor. If the voltages are faulty, replace the control board.
If you can hear the evaporator running and feel air moving in the freezer, the sensor is more likely to be faulty. (The evaporator is inside the freezer at the back.)
The parts diagrams for the FGHS2655PF5A evaporator is here: http://www.searspartsdirect.com/model-number/fghs2655pf5a/1428/0165000.html . Parts are available from other vendors as well. https://www.repairclinic.com/Shop-For-Parts/a4b2d1933346/Model-FGHS2655PF5A-Frigidaire-Refrigerator-Parts is one alternate vendor.
I hope this helps.
Jan 07, 2017 | Refrigerators
None of the evaporator fans are working. Could this be a problem with the main board or the fans themselves?
there is usually only 1 evaporator fan? or do u mean the condensor fan as well? u can check both with a meter for ohms r u saying the fridge still works but no fan operation?
Apr 20, 2015 | Samsung RF4267HARS Stainless Steel French...
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
Freezer flashing E Refrigerator flashing F what does this mean????
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Apr 04, 2011 | Kenmore Refrigerators
Lights are on,but freezer and refrigerator controls are not, is there a reset, lost power for about two hours yesterday
the motherboard located behind a cover panel in the upper left hand corner of the unit is defective,it powers all aspects of the unit and is very sensitive to power surges,outages,blackouts,spikes,etc,you will need to replace it as there is no repairable parts to it,G.E, part # (WR55X10942) just unplug the unit,remove the cover,remove all harnesses to the board and replace(CAUTION) be sure to check both condensor and evaporator fan motors before replacing this board,because if one of these fan motors is bad,the new board will be destroyed immediately!!!
Mar 20, 2011 | GE PTS22LCS Top Freezer Refrigerator
Refrigerators Logo
1,170 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
