Question about X-Micro Technology (XWL11BUSX) Wireless Adapter
Will not connect to the wireless internet connection, it says "limited or no connectivity". When I tried to repair I got a message "that the IP address could not be renewed"
X micro WLAN 11g usb adaptor will not connect to the wireless internet connection
  • 4 Answers
Well how about going to kmart to buy a xbox360 and it will be a earthnet cable in it so connet that to your dsl and thats it
Posted on May 15, 2009
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Limited connection
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 03, 2012 | Dell Latitude D610 Laptop Computer -...
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
My Intel(R) PRO/Wireless 3945BG Network Connection , has a limited connectivity to the internet
Sometime when you switch on the computer and the wireless router (if you turn it off after using it) the computer does not get an IP address from the router in time when the computer finishes booting up. This problem may not occur all the time.
When you get the limited connectivity error, then right click on the wireless connection icon on the Task Bar and click REPAIR. This will get the wireless router to issue the wireless card an IP address.
Then you will have proper Internet connection.
Mar 09, 2010 | Intel PRO/Wireless 3945ABG Network...
The router has #3 link/act lighted up (LAN) and when i connect to internet with router it says limited connectivity, but internet works fine with modem?
I assume you are getting this on your wireless connection.
Sometime you get this message because the computer's wireless card didn't get a issued with an IP address from the wireless router when you opened the browser. This can occur when you power up both the computer and the router at the same time, but the router had not finished booting up in time to issue an IP address to the computer.
You can right click on the wireless icon on the Task Bar and then click Repair, this will force the wireless router to issue a new IP address to the wireless card. When the wireless card gets an IP address then you can access the Internet.
Dec 01, 2009 | D-Link DSL-G604T Wireless Router
My new Toshiba Satellite L300-20W will not connect to the internet via my wireless broadband connection (which is working fine as I tried another computer with it). The Connectivity Doctor gives the...
This problem is common.
This error message occures when the wireless card does not get an IP address from the wireless router. To get the wireless router to issue the wireless with a new IP address the connection needs to be repaired.
Right click on the wireless icon and click on repair.
Jul 30, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
No wireless
you have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
Nov 14, 2007 | HP Compaq nc6000 Notebook
X-Micro Technology (XWL11BUSX) Wireless Adapter Logo
303 people viewed this question
Top X-Micro Technology Computers & Internet Experts
David Payne
David Payne
Are you a X-Micro Technology Computer and Internet Expert? Answer questions, earn points and help others
