Cannot renew ip address
Laptop w wireless connection through dlink route for past year but now will not connect and will requests ip address be renewed but it will not renew it. already did the release/renew, still sends back same message, cannot renew address see network manager
  • junechabib May 12, 2009
    no, still cannot renew ip address
  • 91 Answers
You may have to perform a DNS Flush..Sometimes with wireless, the laptop cache in the IP address that is used when you are connected wirelessly. You can Flush this down the toilet by performing the following command at a DOS Prompt by going to run, and type in CMD, then input the following command in. Once this is done, try to renew your IP again!!
C:\>ipconfig /flushdns
Posted on May 12, 2009
  • AJ Jones
    AJ Jones May 12, 2009
    Try to connect VIA LAN Line (DSL) and try to perform the same steps I mentioned earlier..
May laptop won't connect to internet, my laptop is in good condition. i already reset my dlink wireless router but still don't connect to internet. The connectivity is ok. my laptop detects the router but...
Is the laptop detecting any wireless networks in the area? if yes then it means that the wireless card is ok if not make sure that the wireless is turned on on your laptop.
I the laptop detects wireless networks in the are then we should check the settings on your system or something that could be interfering with the wireless connection on your system,
what are the error/s when trying to connect wirelessly?
Tis can be multiple things regarding wireless, if the error is windows was unable to conenct to wireless evice then try recreating the wireless network on your laptop in network and sharing center if you have win7 on the laptop, network conenctions if you have XP.
I the laptop connects to the router but does not get internet acces then better check you routers network key if it is correct in your laptops settings, also check your IP address if it is correct if you IP starts with 169... then have a bad IP address on your laptop, go to the command prompt type ipconfig /release, then press enter, then type ipconfig /renew then enter to renew your ip address, hoping that the IP address changes it should begin with 192...
Feb 21, 2011 | D-Link DIR-655 Wireless Router
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
Mar 18, 2010 | Google Chrome
Belkin wired voip iad not connecting to internet with macbook
Try opening the Network Control Panel on the MacBook. Select the TCP/IP tab, then click Advanced. Note the list of IP address numbers. Click the "Renew DHCP Lease" button and see what changed. Most likely all of them did, in particular the "Internet Gateway" and "DNS server" addresses. The first is the connection between the D-Link router and your ISP, and the other addresses are for servers that translate your web browser URLs into the IP addresses for the web sites you want to see. The Gateway and DNS server addresses have to match those in the upstream router(s). The routers must have current IP addresses assigned by the routers upstream, and any client computer must have a current address assigned by the first route upstream. You can check into this by logging in to the webpages for your routers and examining the status reports.
Apparently one of the devices in the chain fails to obtain a new IP address when the D-Link router is powered on. I suspect it is the Belkin router. A computer with an expired DHCP lease will probably be using the Internet gateway IP address assigned to the D-Link router when it was on before (in a busy neighborhood, that address would have been re-assigned to some other household). The Windows system may be sending a request for DHCP renewal up the line, which triggers the Belkin router to ask for the same from the D-Link unit, but it may be ignoring the signal from the MacBook or not getting one.
If the MacBook successfully gets online with a manual Renew DHCP Lease request, obtain the owner's manual for your Belkin router (find the model number, then go to the Belkin support/downloads page for that model). See what settings are available to automate the DHCP renewal process.
Jul 10, 2017 | Belkin Computers & Internet
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Dlink router, Dell laptop - no connectivity - won't renew IP
resetting netsh was a good start. I would suggest starting with pulling the power on the router for about 5 to 10 minutes and then plugging it back in. give it a couple of minutes to reconnect to the modem and then try connecting to it again wirelessly. I had an issue with my dlink gigabit that stumped me and a cold reboot was the only thing that worked
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless router dlink dire-301
1) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
2) Check your IP address - Renew your IP address
3) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Oct 28, 2008 | D-Link Wireless
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Wired works fine wireless does not
what is your ip and subnet addresses? are they complete? sometimes I enter my own in the alternate tab. eg.
ip; 192.168.1.105
sub; 255.255.255.0
gate; 192.168.1.1
dns; 192.168.1.1
alt dns; 192.168.0.1
Dec 31, 2007 | NetGear DG834G Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
