Breville ESP8XL Espresso Machine
Problem for Breville ESP8XL Espresso Machine
How I heat the cups in the heating plate?
By giny37 on May 12, 2009
I put then in the heating plate but its seems that they not heating, how long its take for then to heat up? Also do I need to have the tank full to the max with water every time Im going to brew the espresso or I just put the amount of water that I want? Thanx!
Solution #1
posted on May 14, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 332 votes
You can just run some hot water from the machine into the cup to heat it up, just before using, as for the water tank it is always a good idea to have a full tank so that the machine can replenish the boiler if needed.
Was this helpful?
Yes
No
Popular Solutions for Breville ESP8XL Espresso
Questions and Unsolved Problems for Breville ESP8XL Espresso
Do you recommend Breville ESP8XL Espresso Machine?
Answer
Answer
Filters don't fit into filter holder. Can't put filter holder into place onto machine
Answer
My frother no longer functions. What should I do?
Answer
Why am I having difficulty getting a rich cup of coffee when I pack down the coffee in the filter
Answer
When I turn the dial to espresso it makes the sound that the steamer makes and no water comes out.
Answer
the little part were the cofee comes out from is clogged and the water and coffe comes out of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Breville ESP8XL Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
