E3 keeps poping up
Maytag mah8700aww washer keeps showing e3 lots of times during a wash cycle
  • 34 Answers
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
Posted on May 13, 2009
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My washer has passed all the diagnositc test BUT when running through a simple quick cycle it keeps beeping E3
e3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 02, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Maytag front load washer keeps giving an E3 error during wash, rinse and spin cycles. Not all the time. Sometimes restarting the washer works, othe times not. It seems the error occurs when the tub won't...
The machine control ("main computer board") is attempting to drive the motor but not detecting any tach response from it. The E3 fault code appears when the rotor or the drum is locked or the Hall Sensor is faulty. But the intermittent behavior of the problem suggests a loose wiring connection. Check the harness that connects the Hall Sensor and the motor to the machine control and make sure the connections are snug fit and not corroded. Clean the connectors and terminals then reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. Replace the wiring harness if necessary or if it is badly corroded.
Indicate the exact model number of the washer if the problem is not addressed above for further advice.
Jun 06, 2010 | Washing Machines
My maytag neptune mah8700aww is showing a nd code do i need to replace my pump
I would first check the drain stand pipe to see if it is clogged in any way. You can watch it during a drain cycle, assuming your washer is draining, and see if it backs up in there. The next area I would check is the drain hose itself. Make sure it is not kinked, or blocked either. You can check for blocks by pulling the hose off and running a semi rigid object through it. A close hanger, straightened out will work most of the time. If all is clear, and you are not getting any other codes on your display, then the pump is the next thing to check.
Apr 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Front load washerMAH8700AWW.
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
Dec 12, 2009 | Maytag Neptune Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
My Maytag Neptune fnt loader Model# MAH8700AWW Ser# 12227145GR
I have the same problem. The technician seems to think it could be the water is not emptying during cycles. It keeps adding water as the cycles continue and therefore over flowing the tube when it spin. He thinks it could be a water level sensor. Not sure at this point.
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
579 people viewed this question
Top Washing Machines Experts
