I've an old Batesias LT-17 LCD that I would like to use for my new Acer Home Vista PC, but this doesn't support the monitor so how do I fix this?
  • 16 Answers
SOURCE: 17"LCD Monitor
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area.Check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
C-m0n3y
  • 34 Answers
SOURCE: how to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Posted on Feb 21, 2008
SOURCE: monitor flashes primary colors
Ha ha, no it was something very simple. My technician rang the company as it was under warranty and they had never heard of it but worked it out and just pressed a few buttons on the monitor and it was gone!! Thanks, anyway for the laugh.
Posted on May 12, 2008
SOURCE: Moving line in LCD monitor
Just change the 4 capacitor near of the regulator area of the power supply...
that will fix your problem
Posted on Aug 03, 2008
Fix-4U
  • 293 Answers
SOURCE: acer 17 inch LCD Monitor
Hi...there,
Well, that tell you that you got a busted inverter. Need replaced a new backlight inverter or repaired it... Have a nice day!
Posted on Oct 10, 2008
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
Dear sir, my lcd monitor 17"
> after getting Internet connection of my PC, that trouble came.
That probably has _NO_ affect on your LCD monitor.
You could either:
* live with the problem, spending NO money
* spend $50 to $75 for a TV/audio/video technician to try to fix it
* spend $50 to $75 to buy a used 17" LCD monitor
* spend $100 to $150 to buy a new 19" LCD monitor
Nov 12, 2010 | Acer Computers & Internet
Two bright lines on my acer 17" lcd monitor
You have failed TFT driver in the T-CON board, in other word, nothing you can do to fix it without replacing the LCD panel.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 06, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Batesias V171RUXRA Monitor bought at thrift store. Have no user manual or set up. Don't know what the red and white Connection on back of monitor are for. I assume Speakers. What type of connect cable do I...
Spec: http://www.buy.com/prod/batesias-v171ruxra-monitor-17-1280-x-1024-40-ms-0-264-mm-silver/q/loc/101/203255971.html
Not much of the user manual on the wbe that I can find. You will need the VGA cable to hook it up to your PC for the Video, and mini stereo male to male phone jack for the sound. I am not sure about the power, some websies say it uses AC adapter (Regulated 12vdc 3.5A, http://www.directreplacementbattery.com/viewbatteryfor.cfm/LCD-Monitors-BATESIAS-V171RUXRA-LCD-Monitor-58161-FS1501-1789.html), some says it uses Power cord (no AC adapter). Pictures will help.
budmrtn@aol.com
May 25, 2010 | Batesias V171RUXRA (Silver) 17 in. Flat...
Hello i have a acer lcd model AL 1715 SM it doesn t have a vga input and cable is damaged how do i chenge it
Apr 07, 2010 | Acer AL1715 17" LCD Monitor
My acer monitor shutdown after 1min on
Look inside to see if it has any bad caps in the power supply, also look for 5v and 12v in the power supply, 90% of failed monitors are due to bad caps, see examples here: http://s807.photobucket.com/home/budm/allalbums
Jan 15, 2010 | Acer AL712 17" LCD Monitor
Monitor won't stay on
What type monitor? CRT or LCD? Most likely a power supply issue.
Jun 13, 2009 | Batesias V171RUXRA (Silver) 17 in. Flat...
V172RTNRA 17 in. LCD is strobing.
I solved my problem when I tried using a different Power supply. The Batesias V171RTNRA uses a 12V 4.2Amp positive center post power supply. I discovered that I had a 12V 3.0Amp power supply that had belonged to a hard drive and decided to give it a try.
It worked like a charm. Something had gone bad with the original Power Supply causing strobing in the picture. With the replacement Power Supply it no longer strobes and works perfectly.
I am not sure if it's the lower Amps that solved the problem or not.
Jun 29, 2008 | Batesias V171RTNRA 17 in. LCD Television
Screen Shaking/Vibrating
Yeah, Degaussing is basically resetting the magnetic field inside the monitor. go into the menu options, and search for that option. if this does not work, then your monitor is really old, and needs replacing.
Jan 26, 2008 | Batesias V172RTNRA 17 in. LCD Television
New LCD ACER 17
It sounds like it is a settings issue in Windows, you should be able to fix it by following this order:
Go to your Start Menu>Control Panel>Display>Settings>Advanced
Click on: "GEForce Go XXXX" and on nView Display Mode change from Single Display to either "Clone" or "Dualview"
Than click apply and that should fix your problem.
If that doesn't work, than download the Acer Driver with the for Windows XP if your monitor is certified for vista.
This is a common issue with vista,
Hope this helps!
Dec 25, 2007 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
