Question about HP LaserJet 4 plus Printer
Hp laserjet 4 plus printer, message window "Ready", off line button shows red
My hp laserjet 4 plus printer was working up until a few weeks ago.  Now, the message windown says Ready, but the off line button stays red.  The button has to be green in order to print.   When I press the off line button, the light goes off, but then the message windown shows Off line.  Any suggestions?  I have no manual for this printer.
  • swim mom Oct 15, 2007
    Thanks for the idea, but it did not work.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Posted on Oct 15, 2007
  • CheckitRight
    CheckitRight Oct 16, 2007
    sounds like the display panel may be bad ( where the buttons are) if it says ready and the light is red then goes to offline when you push the button there is a bad board. try changing the display panel first.
    e-mail me if you want the part for it at
    pakapala@gmail.com
How do you reset a HP Deskjet 3050 printer?
To do a soft reset
1. Press MENU
2. Simultaneously press and then release the * button and the # button
3. Press the < or > until the message REINIT FFS appears on the 2nd line of the display
4. Press "Check mark"
5. The process will take about 2.5 minutes. The control panel display will change a few times before coming READY.
6. When READY appears press CANCEL
Jan 02, 2011 | HP LaserJet 3050 All-In-One Printer
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
Jun 04, 2010 | HP LaserJet 4 plus Printer
HP Laserjet 1012 - Little smudges on page.
You probably have an excesive amount of toner building up on your rollers or fuser. A cleaning done by a certified technician should take care of this problem for you.
May 28, 2010 | HP LaserJet 1012 Printer
Keeps printing documents over and over - things from yesterday and last week even!
Try doing a soft reset to see if your can clear the printer's memory cache:
  1. Press MENU/ENTER.
  2. Simultaneously press then release the * button and the # button to enter the Developer’s menu.
  3. Press the < or > button until the message REINIT FFS appears on the second line of the control-panel display.
  4. Press MENU/ENTER.
  5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready.
  6. When the Ready message appears on the control-panel display, press CANCEL to exit the Developer’s menu.
Mar 16, 2010 | HP LaserJet 3015 All-In-One Printer
No printing, printer says ready, will test print from menu button
Go to my computer, click on control panel, click on printer/fax and see what is set for default. What ever printer icon that says ready, right click and set as default.
Mar 11, 2010 | HP LaserJet 4 plus Printer
HP Laserjet M2727nf locks up /nothing works. Turn off and no, works for a few menines. Then smae above happens. No code
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Nov 10, 2009 | HP M2727NF Laserjet Printer
Red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330MFP quit recieving & sending faxes
Your Line Interface Unit (L.I.U.) is bad. The part # is C9138-60001. Google for part availability.
1 Open or remove the left side door.
2 Remove one screw at the left of the formatter board.
3 Disconnect the flat flexible cable from the connector.
4 Rotate the LIU around the hooks to remove.
It's about a 5 min job. Good Luck.
Feb 17, 2008 | HP LaserJet 3330MFP All-In-One Printer
HP LaserJet 4 plus Printer Logo
472 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
