Question about HP Pavilion DV6745US Notebook
Shutdown & startup - HP Pavilion DV6745US Notebook
  • John Viguers
    John Viguers May 11, 2010
    Please provide a bit more information:
    Manufacturer, Model Number, Operating
    System,
    any thing you can think of to help us
    help you.
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
Tip
Quicker Startup/Shutdown
Plug in device and view memory contents, delete the startup/shutdown(antitheft) images (back them up if you want).<BR><BR>
Unit should startup/shutdown faster now.
<BR><BR>
You could also use this method to change the images to your own personalized startup/shutdown pics. Just copy over your pics, and name them to the same names of the images that were on the tomtom.
on Mar 11, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
My laptop samsung NP300E5A when i make wifi off and i shutdown when i startup i found wifi on i want keep it off i want keep wifi and blutouth as i make off or on when i restart my laptop
Click on Charms menu > Settings > Network Connections, then set the device to airplane mode. If this doesn't resolve the issue, you may want to also contact Samsung Support directly.
Apr 17, 2013 | Samsung Computers & Internet
My laptop is automatically shutdown when they normally boot-up
if you can, hit start, if it is xp hit "run", type "shutdown -a" without the quotes, then hit enter. you will have to do this fast before the 10 seconds. if it is vista just hit start, then type "shutdown -a" and hit enter. if you are quick enough, the shutdown will abort. now, go to the startup folder in start>all programs>startup and delete anything there if you don't know what it is. this might stop it from happening again. someone might have put a shutdown command in the folder as a joke. it could also be a virus. so if this fixed it, download spybot search and destroy and run a scanmobile crusher http://www.lzcrusher.com
May 09, 2012 | Toshiba Computers & Internet
I have a imac G5 2005 rev c and when it starts upit goes too a blue screen with a small folder in the middle with two faces on it that flash
Try a safe boot.
Shutdown your machine. Hold down the shift key. Poweron. Wait awhile Wait awhile while you harddrive
is being checked.
http://support.apple.com/kb/ht1455
Could be a corrupt disk. Run Disk Utility.
I suspect disk corruptions.
verify & repair your startup drive
To verify & repair you file system on the startup drive, you will need to run disk utility from you installation DVD.
This article will tell you how to get to disk utility. Once in a disk utility, you can go and attempt to recover the disk.
http://support.apple.com/kb/TS1417
To repair your startup drive, you will need to run disk utility from your startup DVD.
Mac OS X 10.4: About the utilities available on the Mac OS X 10.4 Install DVD
http://support.apple.com/kb/HT2055
Sep 18, 2011 | Apple Computers & Internet
Dns-323 automatically shutdown few seconds after startup
had you found a solution ? i'm front the same problem :(
Aug 01, 2010 | D-Link Dns 323 2-Bay Network Storage...
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
My laptop shutdown when i logon because of virus
Have some diagnosis to Safe Mode to remove any virus inside your Laptop. By using such malware & spyware remover, trojan & worm remover is necessary to run in the Safe Mode.
At the StartUp Configuration, DISABLE ALL running programs to minimize any pop-ups comes out.
Sep 29, 2009 | Dell Inspiron 6400 Notebook
Problem with shutdown
Is there any error or the System hang out during Shutdown!
You can do one thing disable the startup items from the msconfig.
Go to start -->Run-->Type msconfig --> open the startup tab -->uncheck or disable all items listed here.
If you face any difficulty add more details, so we can further investigate the problem.
Regards
Ellin
Oct 06, 2008 | Compaq Presario 5000 PC Desktop
HP Pavilion DV6745US Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
