Question about Cyberhome CH-DVD 300 DVD Player
I can't get to work the set up function on my remote control
Wthen i try to play any dvd the tv screen becames blue and stays blue,with no sound no image.....can you help me? thanks...
  • clive pearson
    clive pearson May 11, 2010
    before yo press play do you get anything menu or suchlike ?....vortash
    President:
  • 814 Answers
You must look into the owners manuals of both units and check the correct set-up procedures.Check to see if the remotes for both units must be used for playing dvds.Check to see in you using the correct output to input cable connections. If you are using a third unit in the hook-up look in the owners manual for the correct connections and the correct setting for the use of it with the other two units.The only way to be sure you have you hook -up correct is by useing the owners manuals, because the have all the details for these set-ups. Hope this helps you with your problem.
Posted on May 15, 2009
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
How u get it off the **** screen When i hook up my xbox its comes on but its on the left part of the screen & the right side stays blue
Good day!!!
Please try to input other device such as DVD player to determine which device (x-box) or (TV) need to set up full view settings..
If you play DVD and the screen is fine so you need to set up the full view of your x-box using remote..
If you play a DVD but the screen is still half..You need to set the full view of you TV using remote..
I you have more queries and clarification just add a comment..
Hope it helps..
Thanks for using fixya..
Oct 01, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
Polaroid tv
As a home theatre sales person, i can say that i have had my fare share of dealings with new TV manufacturers. Although sometimes what i am about to say sounds a little abrasive, it seems as though youve fallen victim to the newly developing 'disposibility' trending in electronics manufacturing. You may have already tried using the on board controls, and if that works, try an advanced learning remote control to regain control of the functions. if the onboard controls arent working either, you could try to send it in for repair if its under warrenty, or look at buying a new flat panel. The avg repair cost on an lcd is 300-600 for parts and labor, there are many 1080p 40-42 in the 600-800 range.
Dec 17, 2008 | Polaroid FLM-4201 42 in. LCD Television
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
How do I get to the ''Menu screen'' when playing a DVD movie?
It's likely the remote has the wrong code, so it will only work certain functions. You need to try lots of codes, if you do not know the player's code, till ALL function buttons work, not just some.
Aug 09, 2017 | Logitech Harmony 670 LCD Remote Control
Magnavox mwd2205 - VCR Function
grace0308, Many of the combo units have multiple video outputs and some, like the SVHS and RGB Component outputs, are for DVD only. Make sure that you are plugged into the proper video output. Play a tape and try them all.
Mar 08, 2008 | Philips Magnavox DVD/VCR Dual Player
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Cyberhome CH-DVD 300 DVD Player Logo
53 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
