Question about Radio Shack Cinego D-1000 Multimedia Projector
Poor Image The picture has become very faded. It is like looking at the movie through a thin white sheet, but the menu display is crystal clear. Does it need a cleaning or is the bulb going out?Thanks.
  • Anonymous Mar 21, 2014
    No additional details.
    Benq model 7200
  • 167 Answers
Clean the lens with lens paper or change the bulb
Posted on Jan 26, 2008
Error ce40
Read this
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
When playing the system it will start out with a very clear picture then after awhile the image will start going out like going into black and white, fading, or just going to straight static. How do I fix...
dirty contact surfaces on the end of video cable or the switch box terminal are suspect. you can use very fine sandpaper rolled to clean inside the plug on end of cable. a wiggle test should find the poor contact.
other cause, overheating video in game unit. clean vents
Sep 11, 2013 | Atari 2600 Console
How can i improve my tv LG LH20 42" in terms of
There are a couple of things that you can try to see if the image clears up, or is to your liking. You can adjust the resolution of the picture via the menu in the tv. You can also try resetting the tv to the factory settings, via the menu. You can also try auto configuration, which is also a menu item. If you are using a dvd/blu-ray player, use the HDMI cable for optimum picture quality.
Mar 08, 2011 | LG 42LC2D 42 in. LCD HDTV
I have my settings on sports for a high contrast and nice bright sharp color and in the last 2 weeks the color has gotten darker. Like the contrast is slowly starting to fade away. On blu ray movies the...
you have to check preset picture mode if still not good then reset setting in setup mode.after that your picture become good. if problem still then there is problem with LCD panel.
Oct 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
How to Add a Background Picture to a Microsoft Word Document 2007
t is easy to add a background picture by using the Watermark feature. First, you will click on “Page Layout”. In that menu bar (or ribbon), click on “Watermark”. A window menu will open. At the bottom of that window menu, click on “Custom Watermark”.
In the new menu that opens, check “Picture Watermark”, then “Select Picture” to find an image file on your computer to use. You have the option to have the picture look faded, as a watermark, or displayed in its full color. Check “Washout” for the faded option, or uncheck, to view the background picture in its full glory.
You will then need to choose the size of your background picture, by selecting one of the options under “Scale”.
To remove the watermark, simply click “Watermark”, and choose the “Remove Watermark” option.
Even if you don’t choose the “Washout” option, the background image will appear faded while you are working on your page. But, if you view the page through “Page Preview”, you can see how the background will look when printed.
To get to the "Page Preview" command, click on the button.jpgOffice Button on the upper left hand corner of the Word 2007 screen. Move your cursor over the "Print" option, and another menu will open to its right. On that menu, click "Print Preview".
Jul 21, 2010 | Microsoft Windows XP Professional With...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
How to print picture wiht crystal report 8.5 using ms access ?
I am not sure if I understand your question correctly but here goes..
if you want to click on a link within crystal report and them show the picture you can use OLE..
in the tools menu click on OLE, select "Create From File" ,
select the object type eg: MS bitmap.
Select Link
Browse to folder where the image exists. and select it
you can now select a Icon or leave as is and it will display the image name..
Clikc OK
now when you run CR if you click on that link it will open and display the image..
if you just want to add a Image to CR
in the Tools Meni select Insert, Picture browse to the folder where the image is stored and select it then click OK and it will be displayed
I hope this helps
Jan 17, 2009 | Computers & Internet
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
69 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
