Question about RCA Televison & Video
3 thin colored lines across the top of screen of an rca r56wh78
Hello!
Well, I just bought a 56'' rear projection tv off of craigslist. I took it home and it looked fine for about 45 seconds then the screen went black with three cored lines going across the screen.
I looked inside for perhaps some fuses to replace but cannot locate any. Anyone know what the problem maybe or even where the fuses are hiding?
Thanks!
Jeremy
  • shmizzle May 12, 2009
    Thanks for the comment, that was what I was thinking... but how do I fix the problem?
    Does anyone know where these fuses are?
You have Convergence Failure Problem...
Posted on May 12, 2009
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
Screen glitches(shakes) up and down rapidly
The Guns are going out slowly. This has been a problem with this model before. There is no quick fix to the solution you can wait until the whole thing goes or have a tech look at it personally.
Apr 22, 2009 | Panasonic PT-56SX30 56 in. Rear Projection...
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
I have a 56 inch RCA rear projection tv model# R56WH78 and it looks like 3d. There are small lines on the top of the screen, a blue border on the left side and a green border on the right side. Also the...
This is a convergence problem that can be either bad connections on the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Let me know if yuo'd like to do this and I'll provide additional instructions. If you go the route of a service call, expect a aprts cost in the $40-$60 range plus the local labor rate.
Dan
Sep 22, 2008 | Televison & Video
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
56" RCA HDTV Projection Model # R56WH78
This is a rear projection CRT TV (picture tubes)Not service-friendly (disassembly,getting parts)more problems compared to other brands....
Sep 12, 2007 | Televison & Video
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
332 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
