Question about Toshiba Satellite Pro M300-S1002X Notebook
My laptop is not turning on and theres no indicator it is charging
    Sergeant:
  • 366 Answers
Try to complete your sentence when you ask for support.
Posted on May 12, 2009
  • Pat Batta
    Pat Batta May 12, 2009
    Is power supply charging? Swap it or check if there is tension on PC plug.
    Is the Battery dead? Remove it and check voltage;.if older than 2 years replace it.
    No POST at all?
    No boise from PC? Fan, relay, click?
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Tip
Troubleshooting Laptop Battery Problems
The first step in troubleshooting battery life or charging problems is to check your owner's manual or the manufacturer's website for how to interpret the status LEDs on the laptop. The LEDs on the laptop will change color or blink when there's a charging problem. The operating manual for the laptop or a search of the manufacturer's web site should tell you exactly what the LEDs are indicating.
If the LEDs indicate that the battery is being continually charged, yet the battery only lasts a short period of time, there's a good chance the battery is worn out or defective. Before giving up, perform one last test to determine if the operating system software is interfering with charging. Let the battery charge overnight with the AC adapter plugged in and the laptop turned off. If the battery won't take a charge with the laptop turned off, you can try powering on, entering CMOS Setup, and letting it sit and charge on the Setup screen for a few hours.
Even if the battery is healthy and the laptop charging system is working properly, the battery lifetime will be variable with how hard you work it. If you're in the habit of turning the screen brightness all the way up and choosing the highest performance battery management profile, the battery will run down much quicker than otherwise. You could change your battery management profile if needed. There are a number of predefined battery management profiles in the operating system, accessible through the little battery icon in the system tray.
The ambient room temperature and the temperature of the laptop (if you've left it in a hot car in the summer or a cold car in the winter) will affect the battery life as well.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 15, 2010 | Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Does power switch have to be on when charging with on board charger?
Laptops that I have worked on do not need the laptop to be switched on to charge the battery. There maybe a LED indicator on the laptop to indicate that the battery is charging when the power adapter is connected.
Feb 19, 2012 | Computers & Internet
Hello. I have a Toshiba c650-18k laptop . I was playing on it.and wen i went to shut down before shutting down it just went off.and wen i tried to turn it on again it is not turning on.I put my laptop on...
Is there any lights indicators lit up on the laptop?
remove the battery and the ac adaptor and press and hold the power button (for 10-15 sec) with the battery and power cable unplugged
now try powering up the laptop
check whethere the bluetooth and the power light is lit up
this indicates that there is a memory dump issue in this case you need to reseat your memory strips
for that underneeth the laptop there will be memory door
unsrew door the and open the door and you can take the memory strips out and reseat it back
Dec 26, 2010 | Computers & Internet
Can I charge up this camera using the computer? I've connected it to the USB and put the USB into my laptop - will this charge up the battery?
It ought to do. Is there no indication on the camera when it is charging? You may need to have the laptop turned on to supply charging power. Some computers supply power to the USB sockets when they are turned off and some don't- my guess is that laptops would be unlikely to do so.
Oct 17, 2010 | Olympus X-875 Digital Camera
The laptop won't charge and the charging indicator doesn't turn on when the transformer is plugged in. It appears that there is a problem with the power port on the laptop.
Use similar power output rated Toshiba laptop adaptor and test it again. If charges, then there should be some problem with the power adapter. Replace it to solve the problem.
If still exists, then the problem may be within the laptops' power circuit and you have to give laptop for service to rectify the problem.
Thanks
May 09, 2010 | Toshiba Satellite P105-S6197 Notebook
The battery wont charge
return your computer. there is a serious problem with either the charging system or the battery.
Aug 16, 2009 | Toshiba Satellite Pro P300 Notebook
Battery
Hi there. You should plug in the charger for an hour or two before starting up the laptop. It will charge before you start it up.
Jan 02, 2009 | Computers & Internet
Toshiba Satellite Pro M300-S1002X Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
