Question about T-Mobile BlackBerry 7105t Cellular Phone
I need a username and password
I can not connect to the internet because i do not know the username and password for the enterprise activation
    Genius:
  • 1,447 Answers
Hi
Please call T-mobile and request to be connected to technical care that specially caters to Blackberry phones.
Hope this helps.
Posted on May 12, 2009
I have a second hand Acer f1,and want to connect to broadband i have connected the ethernet cable and it is recieving ,but when i click on internet explorer i cant connect to net what do i do next ?
is your broadband live? meaning active
if it is go into device manager on pc your trying to connect with and look at devices to see if your network adaptor is active. If you need help just respond and ill walk you through process
Feb 10, 2013 | Acer Computers & Internet
How to program to my new enternet connection
HEllo bro...
I don't know what model that use, however here the best explanation for you..
Preparation:
1. Username and password for router.
2.Username and password for provider internet.
3.Ethernet cable (rj45 connection)
5. Pc /laptop to setup router ( on step i'm referred to pc)
4. Web browser( more preferred to using internet explorer current version)
Step:
1. Plug Ethernet cable to router
2. Plug another end Ethernet cable to pcthat you are using to setup
(Now you have cable was connected between pc and router)
3.Switch on the router.
4.Open web browser. Or click here http://192.168.1.1
5.Some window will popup
6.Enter the username and password for router. If default( mean you don't change username or password,you can leave blank for username and fill password with "admin")
If still can't enter try search at google with your model and brand for username and password default.
7.After success enter, then using the wizard .
8. Fill the username and password for provider.
9.FInish.
For step 7th, to 9th, you can directly go setup internet connection( depend to model, sometimes it just type setup) where you will find ppp username and ppp password.. change it..
Good luck and be careful. sometimes you make it right but router need time to create new connection..
For the best go here Lynksis setup
Jul 06, 2011 | Linksys Cable Modem
How do I find my Network Key..or Password
If you forgot or do not know teh network / passkey of your wireless router you have to follow the following procedure to know the password (i am assuming that you have windows)
1. Connect your router directly to your computer (disconnect your cable / DSL internet from the router)
2. Use the Switch ports (ports marked 1 to 4 to connect to your computer / Do not use the internet port or WAN port in your router to connect to the computer)
3. Open command prompt (Start - Run - Type CMD and hit enter
4. Type IPCONFIG and hit enter. (not down the numbers next to Default gateway (it should be in the format 192.168.1.1 etc).
5. Type exit and hit enter
6. Open the internet explorer and type the default gateway you noted and hit enter
7. You should get a small popup asking for username & password - type
admin (username)
password (password) if this does not work (type admin for password also)
if this username and password does not work then you need to reset the router. (Please refer to the manual for this process)
8. if the username & password works you should be able to access the router page, then you need to click on wireless settings on the router page and then know or change your wireless passkey.
Please reply to the post if you need further assistance.
Dec 24, 2010 | Computers & Internet
Wireless router connected to comcast and computer but will not let my laptop connect to internet
To check the wireless settings of the router, use a computer that can get online.
Follow the steps below:
1. In the address bar of your Internet browser, type 192.168.1.1
2. It will prompt you for the username and password. By default, the username is admin and then leave the password field blank.
3. Go to the Wireless tab. Take note of the SSID or Wireless network name and Wireless channel.
4. Click the Wireless Security tab.
a. If the mode is WEP, take note of the Passphrase and Key (you need to copy only the default transmit key). If WEP encryption is 64 bits, you have to copy the 10 digits security key.
NOTE: If you are using a Linksys wireless adapter on the additional computer, you may use the passphrase for the security key.
b. If the mode is WPA, copy the Personal key or the Enterprise Key.
5. On the laptop's wireless settings, select your SSID and enter the security key that you copied.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
My internet connection requires username and password then how can i store it on my router also it has mac address filtering
To configure the router to store your ISP username and password, please perform the below steps:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on Basic Settings in the left hand side menu and for the first question :Does your internet connection requires a login. Make it yes and enter the required information. Click Apply
Check the below image for more clarification:
http://www.ziddu.com/download/6912448/RouterWGR614.JPG.html
Let me know if you need any further assistance.
Regards
Anand
Oct 13, 2009 | NetGear WGR614 Wireless Router
I have a blackberry pearl 8130 and i can not go on the internet, as soon as i go to the web it brings me to the email sectio,. i tried clicking the home button and it brings me to the begining of the email...
there are a couple of thing you will need to do.
one if your trying to use the Blackberry Browser to get the net you have to have an enterprise account.
if you have a regular account with internet you can use safari to surf or media net.
to configure your blackberry account, go to options and advanced options and enterprise activation
enter your account email and password and activate.
that will give you the enterprise features.
if you need any more help let me know.
Good luck and Thank You for using FixYa
Jun 03, 2009 | RIM BlackBerry Pearl Smartphone
Cant connect my philips wireless router to the internet
Generally the default username and password are
username = admin
password = admin
Jan 02, 2009 | Computers & Internet
Problems with Internet connections abroad via hotel provided username and password
do one thing go to the control panel open internet option then go to connection, delete all the existing connection if there are, then click on add select the wifi and follow the instructions that comes
Nov 10, 2008 | Computers & Internet
I dont know haow to connect Linksys Wireless-G Broadband Router with SpeedBooster WRT54GS - wireless router
  1. Connect your modem to the Internet port of the router. Your computer needs to be connected to one of the 4 Ethernet ports at the back of the router.
  2. Access the router's setup page by launching Internet explorer and typing 192.168.1.1.
  3. It will ask for a username and password. Leave the username blank and password is admin.
  4. Once your in the setup page, set "Internet connection type" with what your ISP requires you to have.
  5. If you have cable ISP, usually it is "Automatic Configuration-DHCP."
  6. But if you have DSL ISP, then it will be PPPoE. You need to know your username and password from your ISP.
  7. Better yet, verify your Internet connection type from your Internet service provider.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
T-Mobile BlackBerry 7105t Cellular Phone Logo
117 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
