Question about Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Wiring My wiring keeps burning of the terminal ends that connect to the heating element, so I bought new wires and high temp connectors buy need to know where to connect the "X" and "Y" up...I found and hooked the ground up. Any help would be great. Kevin
  • oceanair Oct 13, 2007
    Problem Solved, thank you for your help Cerfer39...yes, I put high temp wiring in it also.
  • 709 Answers
Hi kevin,
With the ground already hooked up, it does not matter which terminal you hook the X or Y too on the heater. The heater is AC and a resistive load.  This means it doesnot have polarity, and will work both ways.   You done good getting high temp connectors, do you have high temp wire?
Posted on Oct 13, 2007
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Broiler element does not get hot enough.
I did some work recently on a free-standing electric range.
The broiler element was heating up just a little. It was not getting red hot.
The range was practically new.
I discovered the crimp-on spade terminals to the broiler element had lost their springiness and were not making good contact with the element terminals. The ends of the wires going to the broiler element also showed signs of excess heating due to resistive contacts.
I bought a pack of new, high temperature crimp terminals at the appliance parts store, stripped the wires, and crimped the terminals on.
The original crimp terminals were right-angle. The new crimp terminals are straight. I didn't have a specialized tool for right-angle crimps. The straight crimps worked fine.
Just make sure there's plenty of clearance between the rear cover and the wires coming off the crimps to the Calrod.
Broil element now works great.
By the way, other ranges I've worked on use screw-on terminals instead of press-fit spade terminals. Not sure if press-fit spade terminals hold up after many years of service.
Maybe if an emergency repair needs to be done, could try drilling a hole carefully through the assembled spade terminal and putting in a 4-40 screw to recover the contact without having to buy replacement terminals.
on Jul 14, 2014 | Kitchen Ranges
I have a Maytag Electric Dryer model #MDE5500AYW that will not heat up. When I opened the front and looked at the heating element, I noticed that the wire attached to the heating element (a black wire)...
Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
Jan 06, 2011 | Maytag MDE5500AYW Electric Dryer
Dryer wire looks burned and broken at connector
Is it the large heating element wire or the thermostat wire? If it is sthe thermostat wire just go to hardware store and get repalcement spade for end., if its the larger element wire whole element should be replaced I have seen some people correct it by just rebending wire around the connector for a temp fix but not recommend should be replaced
May 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Wire to heating element burns in two at connection on element. Crimping on a new lug lasts for a few days and then burns again.
Did it just start burning out on its own, or have you recently changed the element or the wire to the element?
It sounds like the crimp isn't nearly heavy enough for the wire. If the wire isn't burned, and the element is the right one, then either the wire is not a heavy enough guage or the crimp is too light weight for that connection.
Dryers are 240 volts and there's a lot of amps going through that connector. If it is not the same as the original, buy a heavy duty crimp ring from an electrical supply house for that guage of wire or at a Home Depot or Lowes.
Let us know if that's not the case.
May 13, 2009 | Maytag Dryers
You will have to replace the heat element, because the male terminal is burnt, which causes too much heat at the connection, and causes the wire to burn. If you can clean the terminal to where its shiny it may work otherwise replace the element
Dec 18, 2008 | Roper REX4634KQ Electric Dryer
New Heating Element; Has Power But Not Heating Up
Let's go over a few things:
  • Your unit uses 220 volts to provide heating.  Some elements are wired to one of the two 'legs' of the 220 giving you 'low'.  High uses 220
220 consists of three wires...two 'hot' (red and black) and a neutral which is white.  Neutral to hot will give you to hot 220.  Measure accordingly and use care!  Neutral and the frame of the stove are effectively the same terminal...for safety.
  • You say some of the wires are burnt or a fuse is blown.  They need to be replaced with proper wire...not just any kind.  There is high temp insulated wire available from many ACE and other home stores or parts shops.  It needs to be thick enough, too.  Make all connections carefully and fully onto clean terminals.  Tighten clockwise.
  • Check the voltage coming to the element on various settings as above.  If you only get 110/120, you have an open supply issue which needs to be found.
Look for: loose wires, corrosion, burned insulation to ground.
Nov 19, 2008 | Belling CookCenter 151 Dual Fuel (Electric...
Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Nov 05, 2008 | Whirlpool LER5636P Electric Dryer
Element won't heat on Masterbuilt smoker
You have to buy new cabinet. Take a look on amazon... here: Amazon com Masterbuilt cabinet. I hope this was helpful. cheers
Oct 19, 2008 | Masterbuilt ESQ30B Smoker
Kenmore Electric Dryer Model # 110.62622101
Wedge, one red wire to the right terminal of the heating element. The safety thermostat should of had a piggy back that fits over the left side terminal of the element and connected to one side of the safety thermostat. Other red to other side of safety thermostat, Orange from the timer (smaller connector) to the respective connection on jumper. Catriver.
Dec 01, 2007 | Kenmore 72982 Gas Dryer
Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
186 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
