My camera is Fuji FinePix A700. Have just bought Dell Inspiron 15 laptop with Windows 8. Will I be able to transfer photos to laptop? Are they compatible?
It doesn't matter to the camera what type of computer you have.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
SOURCE: Digital Camera Fuji FinePix S602 users manual
You can find it in PDF format here: http://www.fujifilm.com/products/digital_cameras/a/finepix_a700/index.html
Have a Merry Christmas!
Sincerely,
Michael
SOURCE: softwear for finepix camera
The A202 is a European model and they do not have updates for Vista that I could find. You can however find the updater program for the FinePix software that includes Vista. http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportSoftwareContent.jsp?dbid=864214&prodcat=644675&sscucatid=664260
SOURCE: Fuji Finepix s1000fd i/o error when loading photos to PC
I had same problem,Vista/Fuji-finepix.
Go to control panel click on Autoplay, camera is under devices probably says " take no action" with red sign.click on the bar and a drop down appears,click on import to windows or ask me first,click save and it should work fine. i uninstalled the fuji software,i assume it has issues with microsoft settings.
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
SOURCE: My fuji A700 shuts off when trying to take a picture!
Try different pair of batteries.... It worked for me.
