Question about Kenmore 64952 Electric Dryer
Kenmore dryer belt pulley appears to have come off, belt is loose, pulley found unattached on the floor of dryer - how to fix?
  • 291 Answers
The pully fits in some groves at the bottom of the motor shaft , the pic should help kenmore dryer - 9b7b31e.gif
Posted on Oct 14, 2007
Dryer was not pulling air out of machine,
This belt and pulley are what spins the fan.Which explains why it is not pumping air.What you will need to do is take the whole front off flip up the top and remove the that point you will see a fan housing on the bottom directly under where the drum need to screw that pulley you found back on to the fan shaft and run the belt that you found from the fan pulley to the front of the drive motor.Then reinstall the drum and drum belt and it's good as new.a good thing to do would be to use some loctite when screwing the fan pulley back on so it will not fall apart again.another little tip is that pulley has a reverse thread so you will need to screw it on counter clockwise.Also on most models with this type of fan you need to get to the drum belt from the back of the dryer to remove and install the drum belt
Apr 16, 2014 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore 110.731102100 Gas Dryer replace belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Kenmore Dryers
There was a pulley at least thats what it looks like laying on the bottom of my dryer how do I fix it to make my dryer spin
hello berna.... that pulley is the idler pulley which keeps tension on the belt which turns the dryer drum. It apparently came unattached or in some cases unbolted. It will have to be put back in position. The dryer belt may also be broken or worn. consiter replacing both the belt and the idler pulley. Joe
Jul 02, 2011 | Roper Dryers
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
Hi again, Your parts can be found here:
The belt is item 30 of this page:
The manual that will help you is here:$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Mar 16, 2011 | Dryers
My kenmore clothes dryer has stopped spinning and is just making
The pulley in question is likely a spring loaded idler pulley, used to keep tension on the belt. It likely hangs onto the dryer's frame, & is held in place by the belt. If you order a new belt from Sears, ask them for a belt path diagram, which should show the proper pulley position.
Apr 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Sears Kenmore Dryer. Model/stock no. 76691100 belt is broken, and a pulley attached to a spring steel L with a 90 deg bend is unattached from the machine. Joe
Nov 29, 2008 | Kenmore Dryers
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 64952 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
