Question about Estate TT18TKXKQ Top Freezer Refrigerator
Smell from refrigerator
How do you get the tray out to clean it, it is under the motor, the estate brand freezer on the top
  • 62 Answers
Without a model number we cannot tell if the tray will come out or not. Some do and some don't. If you can get a rag in there to soak up the water you can do that and then put some bleach in the tray to keep it from stinking again. It should evaporate off.
Posted on May 12, 2009
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
Odd smell when plugged in. smells almost like a lubricant or diaper cream. we've cleaned and bleached everywhere we can. it doesn't smell unless it is running and it is not inside the refrige
in the freezer behind the back inside wall of the freezer there's an evaporator fan motor that could cause this if you were smelling this inside,there's also a condenser fan motor in the back bottom of the machine that blows when it's running,pull out the machine,remove the bottom back panel and check the fan motor to see if any oil is leaking out of the motor.
Sep 15, 2012 | Estate TT18TKXKQ Top Freezer Refrigerator
SMELL COMING FROM LARDER FRIDGE,FOUND THE PROBLEM AT BACK WHITE TRAY ON TOP OF MOTOR A BUILD UP OF SLIME , FINDING A PROBLEM TO CLEAN TRAY,
This is the defrost water that collects on the collection tray - white tray on top of motor. Normally over a period of time the water evaporates off but if there is collection of dirt it can smell. So you need to PULL out the tray - use a screw driver to release the lock and the tray will come out which can be cleaned using a water jet and detergent.
Apr 06, 2011 | Refrigerators
My fridge and freezer smell and I do not know where it is coming from. Have cleaned numerous times with different things including bleach and vinegar. What could be the cause?
  • This is a different smell than I am used to hearing about....You say you have cleaned the fridge and freezer several times. I do not know what was used to clean it with but I would do this.....use bleach on the plastic in the fridge. Try to be sure to get the crisper drawers as well with bleach. It may be strong to start with but the smell of bleach dissipates very quickly. When you get done there is a tray under the fridge that collects water when it goes on defrost cycle(assuming its a self defrosting unit?) I would clean out the tray underneath and if you can get under the fridge by moving it try moping the floor under it with bleach.Ammonia can be used instead of bleach but do not mix them together.
  • When you are all done be sure to have a fresh box of baking soda for the fridge.Open the box and set it in the back on the top shelf, wait 24 to 36 hours and write ma back and lat me know where we stand.
  • I hope this is helpful and please rate me for my answer if you can....thank you and speak with you soon!
Oct 13, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Fridge smell
It sounds as if you may have had a spillage at some stage in the fridge unit and this has gone onto the tray at the rear of the unit at the bottom on top of the motor.There may be some other explanation when you do pull out the fridge to access this tray.It may be easier to clean the tray in position as they can gat damaged if you try to remove them.If so get some soapy water and a sponge then clean out and dry,also some spray dissinfectant in the tray after cleaning will help.
May 03, 2010 | Zanussi ZEBF277W Bottom Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Jan 13, 2009 | Refrigerators
Estate TT18TKXKQ Top Freezer Refrigerator Logo
99 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steven Clarke
Steven Clarke
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
