Question about Whirlpool RS610 Electric Kitchen Range
Cant get range door back on
Whuile moving the range, one side of the range door came unnattached. there is obvoiusly a trick toe keep the hinge open to reattach. How does that work?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Straighten the spring latches first. Then insert both at same time  all the way. then close door. Vitally
Posted on May 12, 2009
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
How do I remove the oven door on my GE range
With oven door about a 1/2" from being closed, try holding door from each side and lift straight up. (slides of actual hinge). A little tug motion on each side will get it to unsnap from a socket. You can open door a little more to clear door moving up. When ready to put back, slide it back on hinges and moving down will kind of snap in place. No screw or button to push.
Jan 13, 2011 | Microwave Ovens
I lifted the oven door off to clean it and now I can get it to go back on. Is there a trick to putting the removable door back on?
Hello.The hinge levers need to be pulled open to the first click.(partially open if the door was on)The door should slide back on the hinge arms and maybe click into place.
builderdale
Feb 28, 2010 | Kitchen Ranges
Moved the stove from the wall and the door came off on the righthand side
The door will just lift off the hinges when you open it to the first position, about three inches open, It might be easier to pull it off the left hinge and put both sides back on at the same time. You just slide it on with the hinges in the slightly open position.
Oct 20, 2009 | Kenmore Kitchen Ranges
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Replacing the oven door to the Whirlpool electric range RF375PXE
There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
Jan 31, 2009 | Whirlpool Kitchen Ranges
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Oven door came off
Got it fixed! I found the owners manual posted on another site with replacement instructions. Expand the hinges from the door and insert a nail or screw into the hole there to hold hinges open. With hanging slots parralel to pins in oven frame slide back into place.Once in place open door completely and remove screw or nail. Couldn't be easier.
Jul 01, 2008 | Whirlpool GS460 Gas Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
The door came off.
On the door by the hinges there are levers that keep the door on the range. You must pull the hinges down away from the door far enough to move these levers towards the door so that when you let go of the hinges the levers will catch on the frame of the door. This will take a considerable amount of force. I suggest using pliers to do this. Then grab the door firmly and insert the hinge hooks as far into the slots as possible. then open the door completely . Then move each lever up and against the body of the range. Close the door and all shouild be ok.
Jun 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool RS610 Electric Kitchen Range Logo
83 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
