The clothes are still very soapy towards the end. What is the problem?
  • gk_0222 May 12, 2009
    Thanks to the both of you. I have tried small loads and I am currently using liquid detergent but it does not seems to help. Looks like I need to call a service man..
  • tom wright
    tom wright May 11, 2010
    If it is a whirlpool inglis make it sound like you have a busted coupler and is not spinning the cloths properly .The coul\pler is located inbetween the motor and transmission.on the bottom if you still need help in how to get there let me know hope i helped:)
  • 23 Answers
Make sure your not overfilling it and use soap as directed. I've had this same problem so smaller loads and liquid detergent helped me.
Posted on May 12, 2009
Tip
Replacing Wiper Blades or Not
Do not replace your wiper blades until you have tried this, get some warm soapy water, soft all purpose cloth. Hose down your front and rear windscreen (if fitted with wiper blades) with normal water, clean the windscreen as you would when washing the vehicle. Get your cloth and dip it into warm soapy water, if your wiper arm stays upright put it in that position other wise lift it up and put a piece of towel or similar under it. Now with the soapy cloth give the wiper blade edge a good scrub, up and down, hold the blade itself with one hand on one end, it may slide out, you will notice the cloth getting black, you are cleaning off all the dirt that is stuck on the wiper blade, simple as that. It is usually that dirt which causes your wiper blades not to clean properly, you will eventually need to replace it but give it a go, you will be surprised.
on Feb 20, 2011 | Chevrolet Chevy Cars & Trucks
Oven control valve wont shut off gas completely
This could be due to a build up of grease or tiny food particles behind the control tap handle;
1/ Gently prise off the handle ( it comes towards you )
2/ Wash handle in warm soapy/detergent water, till clean, then dry.
3/ Use a lint-free cloth or a sponge with warm soapy water to soak the tap control spindle and a plastic knife to clean off any stubborn bits.
4/ Wipe clean , replace handle part, try turning off.
Jaylo264
Jan 03, 2011 | Brown Stove Works TM210 Gas Kitchen Range
The cd will run but will not load , it always returns to the wii menue page when you click on start
make sure no matter which position your wii is in, you always put the disk in with the readable side towards the power/reset/eject buttons.
If that does'nt work clean disk with only damp soapy clothe.
Jan 03, 2010 | Nintendo Activision Guitar Hero World Tour...
Clothes are still damp/soapy after spin. Some water visible at bottom of tub. Is this from too much detergent, or could it be something else?
if this is a front load machine you need to make sure you are using an HE soap designed specifcally for front loaders.
Oct 13, 2009 | Kenmore Washing Machines
Washer is taking forever to go through rinse and spin. It ends with a code nd. Clothes are still wet and soapy.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes washer makes big noise after wash cycle
sounds as though you have a blockage in the pump/hose system stopping the water from getting out quick enough. check the filter out first.
Apr 05, 2009 | KitchenAid Washing Machines
Leaves clothes very wet and soapy
Your pump is clogged. This stops the machine from spinning out or rinsing. You have to locate the thing, (comes under the tub, lower end of big black tube) take the clamps out to clear the muck. Refit as you have dismantled. First try to drain out the water completely or you will flood your room.
Mar 02, 2009 | Maytag Performa PAV3200
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
