Question about Epson STYLUS R230 InkJet Photo Printer
Cannot recognise ink cartridges
Epson r230 red light is on steady. Message say it does not recognise all the cartridges.
  • bigfly49 May 12, 2009
    Yes, it DID solve the problem. I cleaned not only the ic chip, but also the chip contacts on the inside after opening the cover and removing the cartridges.
    The problem was caused by dirty contacts.
    Thanks, askmeprinter.
  • bigfly49 May 18, 2009
    The problem has returned. That's why I have posted this issue again on this forum.
    Sergeant:
    Champion:
  • 240 Answers
Open the door cover of your printer and then clean the tab circuit where the cartridge is installed ...and also clean the tab circuit of the cartridge...maybe it suffered loss connection..
Posted on May 12, 2009
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
  2. Do one of the following:
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  4. Open the cartridge cover.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
    The printer begins charging the ink delivery system.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
I had purchased printer Epson 230X with external ink box when I operate the printer it doesn't work the ink cartridge does not run to and fro both red & green lights are on can we fix it
Jun 15, 2010 | Epson STYLUS R230 InkJet Photo Printer
My Epson Stylus R230 has both red lights blinking alternately
Your printer has reach its maximum count of cleaning and printing. This need to be reset using epson adjustment program. But before resetting make sure that you have replace the waste pad inside your printer or it is much better to point outside the hose where the waste ink goes out.
Jan 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson R230 steady 2 red light on.
It may be a general error. It is caused by cartridge error (won't read the chip), cartridge can't move back safely, or "something " slip to the mechanics. If u use the compatible chip (CISS), try to use the original chip first. The last action is turn off the printer for about 1 hour, and turn on back. It's for clearing eprom.
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
370 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
