Question about Hayward Navigator Pool Cleaner
Hayward Navigator Gets Stuck at Steps
My navigator is 4-5 years old, turns, climbs, as it is supposed to. My only problem is that it will hit the base of our 8 inch steps and just STOP. It will not pull away or turn away. It will sit there for hours with its little feet moving up and down, but goes nowhere. Someone suggested that it might be the gear box that is worn. Any help is welcomed.
    Novelist:
  • 151 Answers
Yes the gear box needs reparing.check out for any malfunctioned wire in the gear box or any blown fuse near the side of gear box.or the gears itself in the gear box needs bit oiling this will solve the problem. keep updated.thanks.please do rate the solution.thank you for using fixya,.
Posted on May 12, 2009
Navigator will not climb walls
You may need to replace the feet/shoes?
Or you may not have the proper feet to begin with?
Vinyl
Fiberglass
Plaster...
all have their own specific shoes.
Sep 30, 2014 | Hayward Navigator Pool Cleaner
I had a Hayward Pool Vac for 11 years properly maintained, but never had to replace any stainless steel part. Thus, only one year ago, I replaced it with a late model Navigator. It stopped moving two...
Hayward navigators have a 2 year warranty on their cleaners. The springs, as of now, are not replaceable so you would need to replace the pod kit. This is under warranty.
May 02, 2011 | Hayward Navigator Pool Cleaner
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
POOL CLEANER GETS STUCK ON THE MAIN DRAIN
If it's an older Navigator and it just recently started to hang up on the drain cover, replace the throat assembly, part 29. The lugs or hold offs on the bottom of the assembly have worn down and are not breaking the suction as the Navigator travels over the top of the domed drain cover. Replaced mine and no longer have the "my navigator gets stuck on the main drain" problem.
Aug 06, 2010 | Hayward Navigator Pool Cleaner
We bought new feet for the navigator and put them on and it won't climb the walls we tried to to change the seetings to number 3 and it still won't climb.
you'll need to increase the suction so it will climb. If it used to climb before and now it won't, even with new feet, it may be a bearing problem with either the turbine or the A-frames. You may have to get a turbine kit with a-frames to make it work like new again.
Jul 01, 2010 | Hayward Navigator Pool Cleaner
The vacuum is moving very slow and not climbing walls
Several things can cause these problems with the Hayward pool cleaner. First, check for improper water flow (which can be adjusted with the flow gauge that comes with your cleaner). Partial blockage of the navigator throat can also cause both of these problems and should be cleared if found. Worn shoes or worn wings can also cause both problems. In addition, there are two other things that could be causing it not to climb (but won't really affect how fast it moves). Check to make sure that the hose isn't too short and that there is not improper ension in the rear flap. Hope this helps. let me know if you have any more questions.
Apr 30, 2010 | Hayward Navigator Pool Cleaner
MY NAVIGATOR IS MOVING VERY SLOW AND GETS STUCK OFTEN ON THE DRAI
Take it apart and make sure it doesn't have trash in the wrong places or broken gears, also check the other end of the hose and make sure you have suction at the unit.
Sep 13, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator gets stuck at wall
I have had the same Navigator for many, many years. I have replaced it's guts, pods, feet and gears whenever things wear out. I have a vinyl pool and it works great. I had a problem with it charging into the wall and just sit there beating it's feet ..... now this was my solution, and I'm surprised that Navigator has not altered the design to deal with getting stuck against a wall. This will sound CRAZY but it works great!! Take a plastic lid for a 5 gallon bucket and cut out a round-nose for the front of your navigator. The curved shape is prefect and you can notch the plastic lid and it will snug right into the Navigator body. This gives your Navigator a round-nose and it will never get stuck against a wall again.
Jun 01, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
231 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
