GE washer wont rinse, drain or spin. Makes buzzing noise
My GE washer was going through its cycle and when it got to the rinse it wouldnt drain and all I could hear was a buzzing noise near the control knobs.
  • 323 Answers
You didn't say which model it is, but by now I assume you know about the small trap at the bottom of the newer ones? On 2007 and back, you have to remove 3 or 4 screws on the bottom panel. You'll see the rubber stopper screwed in.
Have a pan under it capable of holding at least a quart of water. There will be all kinds of stuff in there.
If that isn't it, you may have a bad control panel.
Posted on May 12, 2009
My GE washer model WDSR2080D2WW, will fill and wash only. When it should drain and go into the spin cycle, all it does is makes a buzzing noise from the timer. This is no matter the cycle setting. What is...
Hi- Sounds like your drain pump is bad, or clogged. Not easy to get to. It could also be a timer issue or an issue with your pressure switch which tells the washer when the water is out and it can go into spin mode. Sounds like you need to have someone out to take a look.
Sep 23, 2010 | GE WDSR2080D Top Load Washer
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
312 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
