Question about Dell Inspiron 1525 Notebook
My built-in microphone is not working on my inspiron 1525. nothing is muted and when i look at the audio equipment installed there is nothing there. I tried to download the driver but it said there was an error.
    Problem Solver:
  • 19 Answers
You can try the steps below and it should fix the problem.
A.Adjust the Audio Source Control Volume for the Microphone
1. Double-click the Volume icon in the system tray located in the bottom right side of the screen.
2. Click to uncheck any check marks in the boxes next to Mute to turn off muting for each volume control.
3. Click and drag each Volume Control slider to the top of the scale, if necessary.
4. Click Options and then click Properties.
5. Click to select the Recording radio button.
6. Click to check all the boxes listed under Show the following Volume controls:.
7. Verify the Mic Volume box is checked and click the OK button.
8. Click to uncheck the Mute box to turn off muting for the Mic Volume, if necessary.
9. Adjust the Mic Volume slider until it is near the top of the Volume Control scale.
10. Click Options and then click Exit to close the Volume Control window.
B. Test Sound Recording with the Dell Diagnostics
Follow the link below to run PSA
http://tinyurl.com/6f3lcd
1. Ensure the system is powered off.
2. Press and hold the Fn key while system is powered off and press the power button to power the system on.
3. Release both buttons in 5-10 seconds.
4. The PSA diagnostics sequence begins. Tests will be performed automatically.
5. A message will display “where the color bars displayed”. Press ‘Y’ to continue testing.
6. Make note of any alert tones or error messages and forward it to us.
7. When a prompt comes to run more memory tests, Press “NO”.
8. Another test starts and chooses option “TEST SYSTEM”.
9. Please select “CUSTOM TEST” from the options.
10. Please locate “Audio”, click on that, and find “quick test only” (right top corner). Start test, by clicking on the start test button.
11. Make note of any alert tones or error messages and forward it to us.
Download and Install the Latest Audio Driver
Uninstall the Audio Driver
1. Click Start and then click Control Panel.
3. In the Control Panel window, double-click the System icon.
4. If present, click the Hardware tab.
5. Click Device Manager.
6. Click the plus (+) sign next to the Sound, video and game controllers category.
7. Right-click the name of the driver you want to uninstall and then click Uninstall or Remove.
Download and Install the Most Current Audio Driver Available
1. Go to the below mentioned link.
http://tinyurl.com/3vlce4
2. Locate Audio and click (+) sign next to it.
3. Click the Audio driver that you want to select. You may have to specify an installation method or operating system type.
4. Click Download Now in the File Name section.
5. Click Save. Using the Save In: drop-down menu, select My Documents, then click Save.
6. Click Open when the download completes.
7. Click Continue.
8. Click OK.
9. Click Yes in the Folder does not exist. Do you want to create it? Window.
10. Click OK, and follow the onscreen instructions.
Test the Microphone Using Windows® Sound Recorder
Click Start, click Programs (or All Programs), click Accessories, click Multimedia (or Entertainment), and then click Sound Recorder.
Click Record, and speak into the microphone. You will see the green waveform react to your voice.
Click Stop.
To hear your recording, click the Play button and verify the volume level.
Posted on May 13, 2009
Microphone is not working
If the microphone is not working but you are getting sound from the computer, check microphone in sound properties to see if it is muted or disabled. If it is not, just install an updated driver for your audio device and it should work.
Hope this helps.
May 20, 2011 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Microphone not working
Go into your device manager which is located in the control panel under system. Then go under audio devices or it might be labeled multimedia devices and find the microphone listed. Right click and press remove. Confirm removal and restart the computer. The microphone driver should now automatically reinstall.
ALSO, dont forget to check the volume settings of your microphone in the master volume settings. It is possible the microphone is just muted.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
Where is Audio line in hole for Dell inspiron 1525?
Line in functions would be thru the microphone jack
Feb 03, 2010 | Dell Latitude D600 Notebook
When i call someone on skype they can hear me but i cannot hear them. my speakers work for other programs just not skype?
The other side microphone may be muted or not selected. Or on your side speakers may not be selected on skype.
Selct "tools" on you skype menu, then select "options" at the bottom. A window should open. Slect "audio settings" on the left you should see selection for microphone and below it audio out setting select the coorect audio out from the pull doen menu or windows default.
You can now test your system by calling "skype test call" just belw that. If it works it is the other end.
Dec 20, 2009 | Dell Inspiron 1525 Laptop
I recently have had issues regarding my Dell Inspiron 1525 built in microphone. I run on Vista and have done some troubleshooting of my own. I have check all volumes and they are all up to 100%. The audio...
double clock at speaker at the left of toolbar then in options goto the properties go to recording option and confirm there that microphone is checked and then click ok
and then over there check the check box of microphone and increase the volume of microphone. hopefully it will work fine
Sep 03, 2009 | Computers & Internet
Hi...
The first thing that you should try is to reinstall the audio drivers
Let me know
Thanks
Smith
Aug 15, 2009 | Dell Inspiron 1525 Notebook
Microphone of PK635 webcam is not working on my PC
Go to Start, Programs, Accessories, Entertainment, Volume Control and make sure that Microphone is not muted. Also check Start, Control Panel, Sounds and Audio Devices, Audio, Sound Recording, Volume is not muted too.
Jun 25, 2009 | A4tech PK5
The built in mic on my dell inspiron 1525 does not work
Have you checked to see whether the correct settings have been selected for the microphone in the Control Panel>Hardware>Audio Devices page? Once you see which driver works (i.e., which one responds to your voice), right-click and set that as the default. Or you can try to set up the Speech Recognition program under All Programs>Accessories>Ease of Access, and try the different microphone settings till the onboard one responds to your voice. Perhaps the SigmaTel driver has been updated since you bought the laptop--go to the Dell Download site and download the sound driver for it, see if one of these helps!
Apr 10, 2009 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
752 people viewed this question
Alun Cox
