Question about Magellan Maestro 4250 GPS
I have a Magellan Maestro 4000 ROM wiped. Does not start
I have a Magellan Maestro 4000. Trying to update the firmware I lost the files. After that, the device would only display the Magellan logo with the progress that and freeze. Even worse, I formatted the flash in an attemp for fixing it. Now it will only access the bottloader menu, and if I push only the power button it won't start. Now it is totally bricked :(. I have been trying to look for winceimg.bin and cks and uboot.bin and cks, but I have not found anything yet. Any help is EXTREMELY appreciated
    President:
  • 1,111 Answers
Try this site..its not an easy fix but it can be done try bricked it the roadmate maestro section...its in there somewhere, i have read it but like i said, its not easy.
http://www.gpspassion.com/forumsen/forum.asp?FORUM_ID=77&sortfield=lastpost&sortorder=0&whichpage=53
Posted on Jun 15, 2009
  • 3 Answers
I think since you formatted your GPS, you deleted all the maps and software on it. Essentially, you can't use your GPS anymore.
Posted on Jun 22, 2009
Magellan maestro 4000 no sound
I did an update on a Maestro 4000 and it seems that I lost my sound.
Mar 09, 2010 | Magellan Maestro 4000 GPS
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
Jul 19, 2009 | Magellan Maestro 4250 GPS
Tried to update firmware and now all I get is a blue screen with the word Magellan across it and a black line across the bottom of the screen. how do I fix it?
run the firmware again and make sure you wait until it tells you to disconnect the usb and wait for the unit to finish the reboot.
Jul 08, 2009 | Magellan Maestro 4000 GPS
HOW CAN I GET THE GPS TO SPEAK AGAIN.
make sure its not muted or volume turned down. if ok then use the hard reset on the side (tiny hole)use paper clip to reset it. if none of those work check your firmware version and see if its the latest..i have the latest updates for magellan 2200t 3100 3140 4000 4040 and 4050
Jun 11, 2009 | Magellan Maestro 4040 GPS Receiver
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4000 Audio Problems
the one i have is 3 month old and im having the same problem, the audio is not working (magellan model 3225)
Mar 17, 2008 | Magellan GPS
Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Feb 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Nov 13, 2007 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 GPS Logo
1,150 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
