Question about HP Computers & Internet
Cd tray is stuck in open position on my HP computer
The drawer is stuck in the open position, i can push it shut, and it pops right back open. I can't use any disks if the door won't stay shut. HELP!
  • 63 Answers
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
Posted on May 12, 2009
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
I have a hp laptop cd stuck inside how do you get it out
CD Drive Tray problems
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
May 29, 2012 | HP Computers & Internet
Dvd stuck in cpu
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Apr 01, 2012 | HP Compaq 6830s Laptop
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
I put a disc from my printer into CD area and I can't get the drawer to pop open. I also attempted to eject it through the computer. HELP!
Look at the front of the CD somewhere on the front, there is a small hole. Straighten out a paper clip and insert into that small hole and push in gently. This should release the CD tray mechanically. Almost all of the computer installed CDs have this feature.
Dec 02, 2010 | HP Computers & Internet
Cd drawer
there is usually a small hole right around the button to open the tray. use a paperclip or something like that and put it in the hole and it should open
Apr 12, 2010 | HP Pavilion dv9000z Notebook
I CAN'T OPEN MY CD PLAYER
You can either open "my computer" and right-click on the CD icon and choose "eject" or put a paper clip in the little hole in the front of the tray and push. This will push the mechanism and start the drawer opening.
If you have something stuck in there, you can remove it. If you don't find anything wrong, you'll need to replace the CD, as the electronic circuitry is going bad.
Mar 11, 2010 | Toshiba Satellite L305-S5921 Notebook
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Computers & Internet Logo
428 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
