Question about Microwave Ovens
Microwave sounds like everything is running fine but food does not get hot. The carasoul goes around and you can hear the fan running. This is a Samsung over the range purchased new in 2003. mo1450ba
    Sergeant:
    Champion:
  • 214 Answers
To cheak it over you will need to remove from wall and then take cabnet off.When you get it off there will be 2 thermostats bypass and run see if heats up make sure you put a cup of water in it so there is a load.If you bypass them and still no heat you will need a ohm meter to cheak the door switches there will be around6 or so.Make sure you short out the capacitor with a insulated handlescrew driver by touching across before servicing hope i helped :)
Posted on May 12, 2009
  • 62 Answers
Check the factory specified magnatron for that unit. You probable need a new one.
Back panel of microwave gets hot while in use
would you not also get hot when in use . if you were heating food to be totally cooked .that is why they have a fan in them
Jun 19, 2016 | Magic Chef Microwave Ovens
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 1 yr...
If it's less than one year old, it would be fully covered under warranty and you should contact the manufacturer to get it fixed free.
Some have longer warranties, and that will be covered in your owner's manual.
Jan 31, 2010 | Maytag MMC5000 Microwave Oven
My xl1800 spacesaver microwave makes a loud squeaky sound when it's running. When I stop it I can hear the spinning slowing down and the sound goes away until I restart it. I'm afraid that it may blow up....
HI, this may be just an isolated issue that concerns the integrity of the fan housing, or fan itself. the motor may be failing slowly. A mis-aligned fan shroud can cause this as well.
I recommend removing the cover to check for any visible signs of misalignment around the fan housing. if the housing is not shifted or loose, the fan motor will be the culprit.
Have it replaced asap, in this case.
Sep 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
98 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
