I have a carrier Modle No. 38YXA042300. I am getting an H5 error message on my Thermistat Control. I have run the Fan only mode and the fan in the air handler unit works fine. On the unit when I ingage the manual override, the condener unit and fan motor runs and cools. The unit will not run when I put the Thermidistat on Cool mode. Can you help me. Andrew Construction Mangement Speicalthes, Inc.
  • 52 Answers
On some carriers they have a lock out feature outside to reset shut down power to furnace for 90secs. and then restart
Posted on Aug 25, 2009
AlvinInside unit fan works; outside unit does not come on. Inside unit showed H5 code once. How do I proceed?
H is most likely for heat pump, meaning error 5 on outdoor unit. My guess would be low pressure since your power to the indoor unit most likely comes from the outdoor unit. Check manual for codes or research model number error codes.
Jun 03, 2016 | Fedders Heating & Cooling
Gettining error 57.03 in hp laserjet 5200 printer
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Dec 22, 2010 | HP Office Equipment & Supplies
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Hi,I am really hoping to find someone to help me if possible. I have a one year old carrier infinity 4ton 17seer condenser and a 5ton variable speed air handler. I has worked fine but now i am getting a...
If this si what I am thinking it is, it will be very hard to find and prove....
The compressor windings have aflat spot and if the motor stops at the right place it will not atart. The voltage goes way up and kicks out the thermal over load and gives you the alarms that you are getting.
The motor cools down and you reset the unit, the motor has moved just a tick trying to start the last time so now it is off of the bad start spot and will take off and run till it stops at the bad spot again....
Did that make any sense???
Long story short your compressor is going bad...problem will be to get it changed under waranty and convincing the installing company that you have a problem that requires a compressor replacement...
See if you can get them on a short leash and have them come before you reset the alarms and hopefully maybe they can catch what it is doing...
This is and will be a tough one... I've been there with a customer or two already... no fun... trying to figure things like this out!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 11, 2009 | Heating & Cooling
My Carrier 58SXC keeps running but with no heat. The fan will not shut off. I checked the thermistat and it is not in the on position. Any suggestion? Thank you
Hi, it sounds like the fan control is stuck on or faulty. This controls the fan in the heat position. What happens is on a call for heat at the t-stat, the burners come on then after a delay, the fan control set at a preset temperature, brings on the fan. When the T-stat and room are up to the desired setting, the T-stat sends a signal back to the main gas valve to shut off. The fan is supposed to run for 45 seconds or so to cool the heat exchanger down and shut off the fan at a preset temperature.It is called and fan/ limit control. Looking at the furnace, depending on the unit, you will see a rectangular box some with a button on them that says manual/ auto, that has a probe inserted into the fire box. It rotates and has a temperature dial with settings on it from the factory. You can see them by removing the cover.There are several types, but you will know it when you see it. You can turn off the power and gently pull it out and clean with a brush. Gently rotate the dial back and forth and hear it click, this is what shuts the fan off.It may not have the dial type.If its a Honeywell it will. After cleaning it, reinsert and restore power. Run it through a heat cycle and see if the fan stops when it is supposed to.If it continues to run, you will need to replace it.You can find one at a appliance parts house or air conditioning supply.Read the instructions when installing. The Honeywell type has a metal strip that has to be cut before you operate it for 24volt control. If you don't, it will send 120 volts through the low voltage controls, burning them out.Remember how it is wired, or draw and mark your wires. Its really not to difficult, but try and clean it up first. It may be ok if you do. They do tend to stick, and lets hope that will solve you're problem. Please let me know, and keep me posted. Good Luck,
Shastalaker7
Dec 08, 2009 | Heating & Cooling
57.03 error
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
Evap. fan motor stays on
Sounds like the control board is bad. Does the fan try to run when the tstat is off. Did you check the tstat. What kind of voltage are you getting at the fan motor. Did you check the capacitor. If you are getting voltage to the motor with no call for fan then the control board is bad. Let me know if you need any more.
Aug 19, 2009 | Carrier Heating & Cooling
E4 error message. a/c option will not work.
i have carrier ac and it showing E.4 it is not cooling at all please help to solve the problem
Jun 10, 2009 | GE APH10AA Air Conditioner
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Jan 25, 2009 | Carrier Heating & Cooling
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
407 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
