Question about Weber Gas Go-Anywhere Grill
Side burner on propane gas grill burns with orange flame ratheer than blue
  • 10,865 Answers
Here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
Posted on May 12, 2009
Way is my machine using to much propane
Are you smelling gas around the grill or tank? Fill a spray bottle with soapy water, slowly turn on the tank valve, and check for leaks at the tank valve, hose, regulator, as well as each gas valve (remove the knobs first). If no smell or leak is found, check your burners to see if they are burning mostly blue. If they are lazy yellow, they could be dirty or partially clogged and require cleaning; or possibly rusted through and need replaced.. If you do have blue flames, consider turning down the burners for a reduced flame and see if that helps.
Apr 30, 2015 | Grilling
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Flame is just orange
there might be a cloq in line or burners like spider webs
.the air and gas is not the right ratio that is why flame is not blue
May 27, 2014 | Fiesta Blue Ember Gas Grill
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Weber Gas Go-Anywhere Grill Logo
876 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
