Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Water does not go to the line that makes ice?
Water goes to the line for just water but doesn't go to the line that goes to icemaker.
    Sergeant:
    Champion:
  • 214 Answers
Yuo may have a frozen water line remove the tube that goes to your ice maker and get a spray bottle with hot or warm water and spray in there till it is clear of ice.Hope i helped thanks:)
Posted on May 12, 2009
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
SOURCE: Amana free o frost refrigerator
My fridge makes a loud rattling noise when turning off and on
Posted on Dec 29, 2009
  • 66 Answers
SOURCE: The icemaker in my ksrs251 quit making ice any
Probaly a fault on water pump.
Posted on Apr 18, 2010
The icemaker on my older kenmore side by side refrigerator doesn't make ice?
What you are probably dealing with is the little valve called (Water Valve) on the back of side of the refrigerator usually down low towards the bottom right hand side if you are facing the back of unit. Its the part that the water line run into and also will be a water line coming out of it going up the back of the fridge and goes thru into the freezer to the Ice maker in the freezer
Aug 08, 2012 | Kenmore Refrigerators
Tip
How to repair an ice-maker of a refrigerator
An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
on Sep 02, 2010 | Refrigerators
How do you get the ice maker to make ice consistently
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | LG LSC27931S Side by Side Refrigerator
Icemaker not making ice
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker does not work
if the ice maker cycles but is not getting water check the water supply valve that supplies the water to the machine it split and sends water to the door and the ice maker that side of the valve that goes to the ice maker could be bad you can test it with a 120 volt line cord plugged in the wall plug to that side of the water valve if it works with the hose disconnected it may be a blockage or frozen line to the ice maker
Apr 09, 2010 | Refrigerators
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it....
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Oct 03, 2009 | Freezers
Not making ice unless I pour water in tray, water does not flow from small plastic line that feeds tray. I did clean screen at suppy line.
It could be the water valve or water switch in the icemaker. Now it doesnt call for water until the thermostat is satisfied.Now if you pour water and it goes thru and dumps into the bucket I would try to change the valve.
Sep 29, 2009 | U-Line Icemaker
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
106 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
