Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Reddy heater r60
Starts up, but won't stay running for very long.  smells strong and lets out smoke sometimes.  it also runs longer with the top off.  with top on it only runs for a second or two.
  • 625 Answers
With the top off see if there is an obstruction between the fan and the back of the heater chamber.  also mounted on the backside of the combustion chamber is a hi limit with two wires coming out of it.  this connects to the flame detector which is in the flame path.  it is a copper cappillary with two spade connectors on it.  once a flame is detected, it generates a millivolt signal that opens and maintains the main gas valve. reddy heater r60 - 01e527f.jpg
Posted on Oct 15, 2007
When my 1990 subaru legacy is cold it runs good then after 10 miles it starts skipping engine light comes on and a strong ordor of gas can be smelled. it does not run hot but when it starts to cut bac
Could be a faulty O2 sensor. The sensor would not take action until the engine warmed up. Have you checked for trouble codes in the engine computer ?
Jul 28, 2014 | 1990 Subaru Legacy
Won't start, but after sitting a day or two It starts right up.
check fuel pressure could have clogged fuel filter or bad fuel pump.
Jun 11, 2013 | 1995 Geo Prizm
1994 corvette running too rich black smoke and coughing low rpm
the brake servo needs refitting and ensuring correct torque
Jun 11, 2013 | 1994 Chevrolet Corvette
My mazda 626 has a strong potent smell coming from the exhaust
You don't mention what that smell is reminiscent of?
You don't mention the colour of the "smoke" and you didn't say whether the engine is petrol or diesel?
You don't mention whether the road behaviour/performance is normal?
White smoke is almost always steam or in the case of a diesel it could be an unburned fuel mist, grey/black is excess fuel and blue or grey/blue is burning oil.
Some steam is fairly normal until the engine and exhaust system is hot but excessive amounts could be one symptom of head gasket trouble. If the engine is drinking coolant and sending it through the exhaust as steam it will sometimes smell spicy.
Burning oil smells a bit like burned eggs in the frying pan.
If the car hasn't ultra-low sulphur oil and fuel the catalytic converter will convert sulphur traces into hydrogen sulphide - the bad egg gas...
Sep 27, 2017 | 1998 Mazda 626
1999 300M sometimes it won"t
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they just stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 27, 2011 | 1999 Chrysler 300M
I am driving a 2006 KB 250 fleetside, just over 101250km. This is my first diesel vechile and i`m abid worried about my fuel consumption. Done a trip to luderitz recently and used about 38 lts for 390 km...
The injectors have o-rings that will wear and cause fuel leak into engine and cause same smoke problem ,but glow plugs are only for engine firing.........you can change o-rings only but if it has lot of miles i would do injectors...
however make sure the fuel rail isnt leaking at injector connection.also check exhaust for excessive heat or noise inside cat.converter if you can shake it.....some come apart inside.....
it would be worth having the engine scanned to make sure 02 sensors are good..they control air/fuel mix and if oxygen level is incorrect it will burn more fuel and sometimes fuel scent but not very bad.
Feb 19, 2011 | 1985 Isuzu Pickup
92 toyota camry XLE Engine oil leak onto manifold
yea i had the same problem, my last mechanic didnt tighten the top where d sprak plugs go in so it was leakin oil all they way down to the bottom where the exhaust runs and was smokin because of that... had it tightned and no longer ne smoke
Nov 11, 2008 | 1992 Toyota Camry V6
Whrilpool ultimate care II
Do you get any noise when you put it in the spin cycle with the lid closed?? if not you may have cooked the motor (easy repair) let me know
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Heating & Cooling Logo
543 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
