Question about Microsoft Windows Vista Ultimate Edition
Lost paSSword for deep freez - Microsoft Windows Vista Ultimate Edition
  • sanket_jobs May 12, 2009
    "lost paSSword for deep freez"
    Problem Solver:
  • 7 Answers
Http://www.scribd.com/doc/5552189/DeepFreeze-Man
Posted on May 12, 2009
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 | Computers & Internet
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
For Deep Freeze evaluations (with no License Key entered):
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
How to un instaill deep freeze
To uninstall:
for more, you can visit Faronics site (http://www.faronics.com)
regards,
dzilog
Jan 10, 2010 | Computers & Internet
How to uninstall deepfreeze frm pc
To uninstall:
Let me know if this will help
Regards
Nov 27, 2009 | Cell Phones
Want to uninstall deep freeze
Give this a go....
To uninstall:
Hope this helps.
Andy
Dec 15, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
