Question about Craftsman 24 Hp 48" Deck Yard Tractor
Will the bolts that came out of the old mandrels handle tapping
Will the bolts that came out of the old mandrels handle being tapped into a new mandrel when replacing?
  • 246 Answers
Hello:
Yes you can Reuse the Mandrall/Spindle Mounting Bolts.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
Instructions for removing Mandrel from Husqvarna Model YTH24
There should be 3 (or 4 dependent on model) mounting bolts holding the mandrel assembly onto the deck. These are self taping bolts and if the mandrel is a couple years old, these bolts normally break when you remove them. The new assembly should come with new mounting bolts.
Oct 24, 2016 | Husqvarna Garden
Air conditioner/heater fan won't turn on
This is usually a "blower motor resistor". Follow the wires from the heater blower across the underhood Firewall. The wire will plug into a part with 2 mounting bolts. 90% of this part is hidden within the ductwork cavity.
Sometimes if you tap the part with a broom handle or snowbrush handle, it will resume working.
Sad part about this is the new part may do the same thing and you have only the Warranty period to protect you. So the old part may function reliably after tapping it and outlast the new part.
Jan 08, 2014 | 2002 Lincoln Town Car
St1300 valve cover bolt
Go to a Ace Hardware store or an automotive store and get a tap for the size of the bore and a tap handle. The tap will re-thread the bore.
Nov 21, 2013 | Cars & Trucks
Remove lock hub from rotors 1995 toyota t100 4wd
1995 Toyota T100 4WD Pickup
Manual Locking Hub - Removal and Installation
REMOVAL & INSTALLATIONSee Figures 1 through 11
Fig. 1: Exploded view of the free wheeling hub
Fig. 2: Turn the handle with your hand to the free position
Fig. 3: Note the directions in which you can turn the handle: left-free, right-lock
  1. Remove the hub cover. Set the control handle to the "FREE" position.
Fig. 4: With the handle in the free position, remove the six hub cover bolts
  1. Remove the cover mounting bolts, then pull off the cover. Remove and discard the gasket.
Fig. 5: Pull the cover off
  1. Remove the bolt with washer.
Fig. 6: Using the correct size wrench, loosen ...
Fig. 7: ... then remove the center bolt and washer
  1. Remove the mounting nuts and washers.
Fig. 8: Next, remove the outside mounting nuts and washers
  1. Using a brass bar and hammer, tap on the bolt ends, then remove the cone washers.
Fig. 9: Using a brass bar and hammer, tap on the bolt ends ...
Fig. 10: ... then remove the cone washers
  1. Pull off the hub body.
Fig. 11: The free wheeling body should come off easily; be sure to discard the old gaskets
  1. Remove and discard the gasket.
To install:
  1. Place a new gasket into position on the front axle hub. Install the free wheeling hub body with the cones washers and nuts. Tighten the nuts to 23 ft. lbs. (31 Nm).
  2. Install the bolt with washer, tighten to 13 ft. lbs. (18 Nm).
  3. Apply multi-purpose grease to the inner hub splines.
  4. Set the control handle and clutch to the free position.
  5. Place a new gasket into position on the cover.
  6. Install the cover to the body with the follower pawl tabs aligned with the non toothed portions of the body.
  7. Tighten the cover mounting bolts to 7 ft. lbs. (10 Nm).
Fig 1.Exploded view of the Free Wheeling Hub
Fig. 2 Turn the handle by hand to the "FREE" position
Fig. 3: Note the directions in which you can turn the handle: left-free, right-lock.
Fig. 4 With the handle in the free position, remove the six hub cover bolts.
Fig. 5 Pull the cover off.
Fig. 6 Using the correct size wrench, loosen ...
Fig. 7 ...then remove the center bolt and washer
Fig. 8 Next, remove the outside mounting nuts and washers.
Fig. 9 Using a brass bar and hammer, tap on the bolt ends.
Fig. 10 ... then remove the cone washers
Fig. 11 The free wheeling body should come off easily; be sure to discard the old gaskets.
Oct 29, 2011 | Cars & Trucks
I need an exploded view of a 1994 toyota 4 X 4 hub
  1. Remove the hub cover. Set the control handle to free.
Pull the cover off
To install:
  8. i hope this is what you are looking for
  9. plz vote comment and reply if need more help
Jan 18, 2011 | 1994 Toyota Pickup
I'm replacing the mandrel housing on the deck. the new housing has no threads in it. Can i tap threads and use regular bolts to mount housing to deck.
The old bolts in the old spindle should be self-tapping. Put a little oil on them and screw them into the spindle. Otherwise, yes, you can tap them and use any good quality grade 5 bolt.
Sep 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I am replacing the mandrell housing the replacement housing does not have threads in the mounting holes. Are they self tapping or do I need to replace with bolts?
You didn't indicate any model or brand. If the housing goes in from the bottom and the bolts from the top, then it's nice for them to be threaded so you don't have to get under the machine, and nothing more to catch grass on. If the mandrel housing sits on top of the machine, I'd use carriage bolts from the bottom with nuts on top.
Jul 07, 2010 | Garden
Can't get nut off top of mandrel shaft
try tapping with a hammer and using small pipe wrench or vise grips, last resort heat up with torch then use pipe wrench or vise grips.
Sep 07, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Do mandrels on 48'' deck come threaded for mount or not?
Most of the time you get self tapping screws with them or if you want you could get bolts nuts and washers (,lock) make sure the shafts and height are right.
May 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
121 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
