Question about HP OfficeJet G55 All-In-One InkJet Printer
I keep getting a cartridge alignment failure with multiple cartridges tried
So I have tried several new cartridges and I keep getting this error. If the printer is broken, how hard is it to fix it?
Press and hold the Enter button, and then press Menu, if it your problem. Take a look here
Good Luck
Posted on Nov 01, 2007
How can I align my HP Photosmart C4680 printer after replacing ink cartridge.
If the new (or refilled/reman/compatible) HP 60 (or 60XL) ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance.
The types of 'more severe' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.), including blinking power/exclamation lights, typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test:
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass:
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
Mar 28, 2012 | Office Equipment & Supplies
My lexmark x 5650 keeps saying alignment error, try to remove tape. I've done this multiple times, tried cleaning the cartridge, and it keeps saying alignment problem. ive unplugged and plugged back in...
alignment error usually means that one cartridge is not printing, or paper tray is empty.
try removing both cartridges then stamp each printhead on some folded tissue paper. You should get one solid strip of black ink with the black cart and 3 colour strips with the colour cart.
If you don't...there is your problem.
good luck
Dec 01, 2010 | Office Equipment & Supplies
I bought a new color print cartrige and since then my printer align cartridge keeps failing so I can't use my printer. I have reincerted them many times and ran the align cazrtride and I get the same thing...
Sorry to ask a dumb question but did you remove the protective tape on the cartridge when you installed it? If yes, then proceed to the following HP help page where the align cartridge error is outlined along with several solutions. Best of luck!
OfficeJet k60 Align Cartridge
Nov 06, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
go to properties on the printer, maintenance, and align the cartridges from there
Oct 26, 2008 | Office Equipment & Supplies
Alignment failure
try to hit set up button then hit opions button to by pass error message
Oct 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
Today I bought and am trying to install an HP Office Jet, designation J5780. I installed the two printer cartridges that were in the box with it, yet a message keeps rolling across the printer stating that...
Who are you talking to? There are no replies to this post except yours.
Try switching the cartridges around.You may have them reversed.
Black in Color slot - Color in Black slot.
Jul 07, 2008 | HP Office Equipment & Supplies
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Ink cartridge error
Check the date on your ink cartridge.  I bet it has expired.  If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today's date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Oct 16, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
208 people viewed this question
Ben Johnson
