Question about Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
My Simpson Sirocco 350 Dryer keeps tripping the power circuit. how can I fix it?
  • witty_chuck1 May 13, 2009
    Unfortunately this did not fix my problem. It appears to have something to do with the heating element portion of the cycle as it only happens when I switch to high or medium heat but does not do it when on "no heat"
  • Anonymous Mar 15, 2014
    Simpson Sirocco 350 dryer. About 13 years old. Used maybe once a week. When the dryer is turned on it trips the circuit breaker for the whole home.
This is probably caused by a broken switch behind the small white panel you can see when you open the door. This stops the dryer when you open the door. It is very flimsy and breaks easily. You can remove it by unscrewing one screw and carefully pulling it out. You can probably fix it with super glue.
Posted on Jul 12, 2012
    Scholar:
  • 43 Answers
The dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
Posted on May 12, 2009
  • John  Love
    John Love May 12, 2009
    let me know if this fixes ur problem, it may be something else.
  • John  Love
    John Love May 13, 2009
    In that case, you may have a short to earth. When the selector moves to medium or high a possible ground fault to earth may be tripping the circuit. This can be checked by plugging the dryer into a sGFI multi-socket.. If it trips while in one of these multi-sockets, you know that your dryer heating circuit has a short to earth and, unless you have a bit of training at fault finding, i'd recommend getting an appliance serviceperson to make a house call. An electrician may be able to meet your needs as well.
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
Whirlpool lgr7648pq0 gas dryer no longer heating; just blowing air; no exhaust issues;
More than likely you have a burned up heating element. There is a remote possibility that you have a blown circuit breaker or fuse in your house. The blower is wired for and only requires 120 volts but the heater element requires 220 volt service. Usually there are two circuit breakers in your house breaker or fuse panel that provide power for the dryer. One of them may be tripped/blown and the other one may be ok..still on...and providing power to the blower. So...check to make sure there is not a blown fuse or circuit breaker tripped. This is the easy solution if it applies but probably the heating element is bad and will need replacing.
Sep 01, 2009 | Whirlpool LGR5636L Gas Dryer
My dryer is not producing heat. Just cool air!
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 17, 2009 | Dryers
Speed Queed AEM677W2 dryer does not blow hot air
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams for DIY assistance.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Firstly, ascertain that you have made a positive heat selection, then read on.
Heating element
Thermal fuse
Wiring
Jul 12, 2009 | Speed Queen Dryers
No heat, seems to be continuity for heating element
Firstly, make sure you have selected/ascertained a heat setting, then read on from the checklist below, supplied by; www.repairclinic.com
Heating element
Thermal fuse
Wiring
Jul 07, 2009 | Maytag Dryers
Not heating up...not drying clothes
Heating element
Thermal fuse
Wiring
Jun 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
HAVE A 8 YEAR DRYER( Kitchen Aid)
I would be checking the service panel. I'm assuming the dryer has been working in that outlet. If the breaker is over 50 amps that is why it didn't trip. But the breaker may be bad itself. Make sure it is wired properly. Red wire should go on one side of the breaker and the black on the other. The white should go over to the neutral bar. Then make sure the outlet you plug into is wired the same way. (MAKE CERTAIN THAT BREAKER IS OFF) The top two prongs should have a red on one side and a black on the other, with the white at the bottom. If these are correctly wired, the problem is either in the breaker or inside the dryer. Depending upon the model you have, a 50 amp double breaker isn't prohibitively priced. If you buy the breaker, wire it the same, turn it on, plug in the dryer and it happens again, the dryer is at fault. Coils burn out inside them, lugs burn through, but I'd feel more comfortable at that point calling a service man, tell him what you've done with wiring, breaker, and outlets. It may be time for a new dryer.
Sirwriter
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore dryer
Hi!
Heating element
Thermal fuse
Wiring
Heating element
Thermal fuse
Wiring
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
Whirlpool 29"gas dryer Model#LGN2000LW1
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 17, 2008 | Whirlpool GGQ8831L Gas Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
Heating element
Thermal fuse
Wiring
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Open Questions:
Dryers Logo
530 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
