Will not operate: operation light gives 5 flashes and then repeats after a period of time, whilst the Timer light is constantly flashing even whilst the machine is turned off. The Timer is in the off position when the machine is switched on and the same sequence of light flashes continues
MINE DOES THE SAME THING! MAYBE YOU CAN HELP US BOTH! MODEL INDOOR AWU36CX OUTDOOR AOU36CX. THANKS
Posted on Oct 12, 2012
  • 400 Answers
You have not specified the make nor model. Five flashes can indicate a blocked drainpan and drainpipe which needs cleaning.
Posted on May 14, 2009
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Model ASTG 34LFCC Economy flashes constantly green then Operation flashes once followed by Timer light flashing once unit will not start up at all even after resetting RCD
Owner's manual flashing number of times probably is an error code. Owner's manual troubleshooting probably will explain the
error. Are you sure the unit has power? doublecheck your Circuit breaker box. Probably a 220vac breaker. Breakers do wear out.
So you may need electrician or AC Technician.
Feb 28, 2015 | Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Fujitsu ASTA12LCC operation and timer lights flashing
You need to record how many times each light flashes before it pauses and then repeats. This indicates a specific error that a tech will be able to diagnose and directs them to the components that have failed.
Dec 27, 2012 | Fujitsu 18C1 Air Conditioner
My friedrich mw18y3f dosent work any more, the operation light and the timer light flash together 4 times and after it's the timer light that flashes 4 times alone. can someone help me
1( replace batteries with FULL charge and the same type alkalines do not mix
2( clean the contacts batteries very well c.cleaner
3)retight the springs contacts with long pliers for better contacts.
4) open the remote control for to clean the keypad from dirty, oxide, corrosion and bad contacts.
5) proceed to reset the code, and try again.
However if do not work, you must go to the repair shop Tv for fix it.
God bless you
Oct 08, 2012 | Friedrich Heat Pump, 18, 000 BtuH, Wall...
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Heating & Cooling Logo
1,266 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
