Question about Compaq Presario F572US Notebook PC
After replacing the lcd on my compaq it lit up but no picture
I had replaced the lcd on my compaq (teenager propelled hairbrush!) it lit up but no picture. I found the video cable needed to be replaced(broken wires at the hinge). I replaced the cable still no picture?!?
I have compaq MV7500 COLOUR monitor n when i turn on the screen then i m getting only white line in the middle on the screen how can i fix the problem
When the following conditions, you need to replace the LCD screen:
No image on the screen, but the power indicator stays in
Dark display but still readable
Results - 1 of 1 / from by by 2 to a few seconds are of the the the the scintillator of the screen and Close for between the
The power indicator has been lit, but nothing display and sound
No image on the in the screen, but the LCD TV still comes with audio
Pictures cycle open and close the, as well as lamp closed for non high-power LED
http://www.lcdinverter.info/hp-pavilion-dv61247eo-lcd-inverter-p-11136.html
May 15, 2013 | Computers & Internet
How to replace the lcd on a compaq presario CQ60-615dx
Here is a website with step-by-step picture instructions on how to replace the lcd on your particular model of laptop.
Thanks, and have a great day!
Oct 03, 2011 | Compaq Presario CQ60-220US PC Laptop
Desktop is black
Hi mistopassio...
Try plugging the laptop into an external monitor..
If the picture comes on..replace you lcd screen
If the picture does not come on...replace the lcd and/or you lcd inverter/backlight
Please take time to rate me thumbs up
Sep 12, 2011 | Compaq Presario Notebook
I have a Whirlpool (2004?), and when I release the reset button, the pilot goes out...as long as I'm holding the reset button down, the pilot stays lit. Even after two minutes, when I think it'll stay lit...
Almost always it is the thermal coupling, change that and try again...They're not too expensive, but you do need to get the correct one...
Alternatively, hook up a bicycle and have the teenagers generate the heat...... << Good luck selling that one. Tell them ALL of the teenagers do it.....
Mar 12, 2011 | Water Heaters
Eveything works except the picture ,it turns on only it has a very dimmly lit screen a void of any picture please help aaaaah
You have a weak electronic component called a capacitor. You have to let a tech replace it for you. This will cause your LCD to suddenly loose brightness
Aug 23, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
Apr 03, 2010 | LG 42LB4D 42 in. LCD HDTV
Compaq Presario cq50-110us LCD replacement
check the video software of your laptop maybe its adjust
Jan 26, 2010 | HP Compaq Presario CQ50-110US Laptop
Hi,I bought a Compaq TFT7020 LCD monitor and the
If your monitor came with software, install it...if not look for an update on the monitor manufacturer's website...there might be a fix for it there. If that doesn't help then check your video driver (which I would do first) to make sure it's up to date. If not find the correct driver and replace accordingly.
Dec 15, 2009 | Compaq TFT7020 (Carbon, Silver) 17" LCD...
Sansui 1908 sound but no picture, kid was using
Return the thing. Ur LCD inverter board is dead.Or call for warrenty repair.The LCD inverter have no set of times,it dies anytime.Must replaced the LCD inverter board to get picture back.
Nov 06, 2009 | Sansui 19 in. LCD TV
The picture is intermittent, stays for a long time,
is the backlight staying lit even with the picture out? I had the same problem with my Aquos LC32DA5U my backlight was always on but no picture at all, just a lit up black screen, the problem is the LCD controller, I replaced that and it's perfect now.
Jan 09, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Compaq Presario F572US Notebook PC Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
