Question about Microsoft Xbox 360 Console
360 just has blue screen
My xbox 360 turns on and has power but just shows blue screen. never any other problems just happened when cut on one day
  • Anonymous May 13, 2009
    Mine has a blueish, greyish screen when playing fallout 3
    Scholar:
  • 86 Answers
Check if it is on the right video imput or check the connections from your xbox to your tv via the three colored cables.
Posted on May 12, 2009
Call of Duty 4: Modern Warfare Mission Problems
Sounds like a bad disc, the rental place will provide another disc for free within a certain time frame.
Jun 21, 2010 | Activision Call of Duty 4: Modern Warfare...
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
My XBox 360 does not show up on the tv screen, but it has sound.
this happens a lot. what happend is the red white and yellow wires that you put in the back of your tv. the red one is not in the right area or
there is a switch right were you plug in that cable with the red whit and yellow cables to your xbox that says hd or normal switch that to whatever your tv is
Jul 17, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 freezes while loading
Try Installing it to your hard drive, it stopped the freezing for me but just took up some space.
Jan 07, 2009 | Microsoft Xbox 360 Console
XBOX
A. You have the wrong inputs on your audio and video, do you know anyone who may've tampered with that? IE older brother, dad, etc.
B. Your 360 has the dark screen malfunction, but if that was the case, you should be able to hear audio.
CrossCut
Nov 02, 2008 | Microsoft Xbox 360 Console
TWO RED LIGHTS ON XBOX 360.
that means it overheating........
Oct 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 has no video or sound on startup
I've fixed that problem several times now with a great xbox 360 repair guide
Mar 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 Fault
Does the light in the power brick is red, orange or green when you turn on the xbox?
Oct 02, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
319 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
