Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Need to change blue tube, just unscrew and replace with t.v. unplugged?
I want to install the blue tube in my 9p5034c103, 50" projection. Do I just uncrew the bulb and replace with the t.v. unplugged and how much for the tube?
  • Philips Master
  • 3,459 Answers
No - Your TV has tubes not lamps.
Why do you beleive you need to replace the tube. 99% of the time the problem with this model is just the fluid.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
Posted on May 14, 2009
How to replace blue gun on Samsung HCM553W
What makes you think Blue tube is Bad ,It may just need coolant fuild changed out.
Feb 19, 2010 | Samsung HCM553W 55" Rear Projection...
Turn tv on screen is light blue then picture fades then, screen shuts off???
Blue tube is bad need to replace blue tube.. Tube no longer avail will need to be special ordered and my run from 350.00 up to replace part.
Feb 04, 2010 | Sony KP-57HW40 57" Rear Projection...
The blue projection light is off, like it has dust on it. so unscrewed the front screen, cleaned the lights now the red and green are blurry looking. any help ?
You probably knocked or moved the focus lenses when you cleaned the lights (these are actually 3 picture tubes) Each lens has a wing nut that tightens to lock the focus in place if this was moved your focus would be off. Does the blue tube light at all? and when the TV's on is the image clear when you look directly into the Tubes? (the image should be bright and clear -not milky.)
Oct 16, 2009 | RCA P52960 52" Rear Projection Television
CRT Arch / Blue Tube, Now what do I do.
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
Sep 21, 2009 | Zenith R56W36 56" Rear Projection...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
The blue CRT is shorted out. You will need to replace the Blue CRT. You can get replacement CRts at the following link for your model. http://servicemanuals.vstore.ca/
Jan 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 60SBX78B Blue Convergence Issue
You need new convergence ICs. its an easy repair. You can get replacement ICs at the link below and they provide free installation instructions with pictures as well as free tech support.
Apr 22, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 53uwx10ba rear pro
Set needs convergence ic's changed (STK392-110). Also look for resistors slightly discolored around STKs, usually low value like 1.5 ohm, 2.7 and 3.3 If you have an ohm meter and a soldering iron, solder and solder wick, you can attempt this yourself. Remove rear cover of set. Mark and unplug connectors from convergence board, including small jumpers that interconnect boards. Remove board, turn over and unsolder pins of conv. ic's using solder wick. Unscrew mounting screws and pull chips out. Careful, white heatsink compound is messy. Apply new compound to new chips if needed, making sure not to bend small pins. Slide chips in and screw in mounting screws. Flip board and solder in ic's making sure all pins came through. Check for small resistors around ic's being discolored,(usually 1.5 ohm) These are critical and a few tenths of an ohm change will cause extra alignments needed. Replug and secure board. Double check that all connectors are in place and power up unit. If you changed any mechanical adjustments to tubes or lenses, change them back now and try auto convergence. Service adjustment procedures are avail. online if needed. Good luck!
Mar 01, 2008 | Hitachi 50UX57B 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Red ghosting
pretty simple, unplug the power, ground, red, green, and blue plugs...unscrew the entire board...replace with the new parts...put it back in...
Nov 06, 2007 | Samsung HCN4727W 47" Rear Projection...
KP-51HW40
the unit needs either a screen control or a new blue tube.If it needs a tube,sony is aware of many units with manufacture defective tubes
Mar 05, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
302 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
