A/C Airflow only coming out top and bottom, barely from front vents
All the air seems to be coming out of the top or floor vents. There is only a very little air flow coming from the front vents. Someone said that it is probably a vacuum line. If so, how difficult is it to find and replace? Any tips would be greatly appreciated. I have a 96 Chev Blazer S10 4.3 THX Ken
  • 15 Answers
The most common cause is a disconnected or broken vacuum line in the vacuum reservoir, a black plastic sphere located just above the driver side of the hood hinge
Posted on May 13, 2009
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Air conditioning will not switch from defrost vents
Vacuum control motors are used to position these airflow control doors.
SECTION 412-01: Air Distribution and Filtering 2000 Expedition/Navigator Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 06/17/1999 Air Distribution There are two sources of air available to the air distribution system:
  • outside air
  • recirculated air
Recirculated air is only used during MAX A/C, AUTOMATIC (if equipped with EATC) and OFF modes.
Air distribution within the vehicle is determined by the function selector switch position, if equipped with manual A/C, or is controlled by the electronic automatic temperature control system in the AUTOMATIC mode but can be overridden by the driver if desired. Airflow control doors are used to direct airflow within the heater air plenum chamber. Vacuum control motors are used to position these airflow control doors.
The air distribution system is designed to provide airflow from the defrost nozzle when no vacuum is applied to any of the vacuum control motors. This is done to prevent a situation where defrost cannot be obtained due to a system vacuum leak.
Air enters the passenger compartment from the:
  • instrument panel A/C registers.
  • heater outlet floor duct.
  • windshield defroster hose nozzle.
  • side window demisters.
  • rear seat airflow duct (if equipped).
Passenger compartment air is exhausted from the vehicle through open windows or cab air vents.
expedition air flow hvac system-xvcmtr1jbqa4kfrdszeh0lpe-3-0.gif Item Part Number Description 1 18A318 Vacuum control motor - panel/defrost door 2 18A478 Panel/defrost door (full vacuum position) 3 - Defrost airflow 4 - Side window demister airflow 5 18B545 Temperature blend door (full heat position) 6 19860 A/C evaporator core 7 19A813 Air inlet duct door (full vacuum position) 8 - Outside air inlet 9 18A318 Vacuum control motor - air inlet duct door 10 - Recirculated air inlet 11 19805 Blower motor 12 - Vacuum to emission control 13 - Vacuum from the engine intake manifold 14 19A563 A/C vacuum check valve 15 19A566 A/C vacuum reservoir tank and bracket 16 19B888 A/C-heater function selector switch 17 18476 Heater core 18 18A559 Floor/panel door (full vacuum position) 19 - Floor airflow 20 18A318 Vacuum control motor - floor/panel door 21 - Panel vent airflow
Check vacuum control to the panel defrost motor ( vac,diaphragm )
Nov 01, 2017 | 2001 Ford Expedition
Rear Floor Vent heat only
Sounds like your heater coolant hose door flap is broken or loose. May want to check behind the heater controls, if your components are mechanically operated. If electronically, may need to perform more troubleshooting before replacing this component.
Jun 17, 2017 | 2004 Ford Econoline
2003 Chevy trailblazer, the 4 front dash air
{: ) Check first the fuse labeled HVAC1 10A at the rear fuseblock. If okay, the mode actuator could be faulty. You can try this: turn ignition switch and a/c off for a minute. Then turn ignition on, wait forty seconds. Afterwards, start the engine, and check your a/c again.
Aug 01, 2010 | 2006 Chevrolet Trailblazer
Heater/AC vent option knob produces knocking sound in back right corner. i.e. the knob rotates from vents in front to half front half floor to all floor to half floor half defrost to all defrost. the...
If I am reading correctly you are hearing the vent doors moving to redirect the airflow to the vents you choose. This is normal and can be more noticeable if the blower fan is on, putting air pressure against the doors.
Jan 09, 2010 | 2003 Chevrolet TrailBlazer
Our range venting microwave doesn't seem to **** up the steam from the range top. A lot of air comes out the top,but the steam seems to be going in.
We have the same problem with our lmvh1750st lg brand, there is 5 settings and alot of noise and airflow out the top. Very little from the bottom actually seems to go into the vent. We are very disatisfied with this and find during normal cooking we have very little help from the vent hood.
Oct 27, 2009 | Bosch Microwave Ovens
Air is barely blowing out of the vents, hot or cold.
The blower motor resister shorted out common problem. It is located behind the glove box on the HVAC assembly.
Jul 16, 2009 | 2004 Jeep Grand Cherokee
2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
May 26, 2009 | 2004 Ford Expedition
Loss of a/c air through front vents
You have a vacuum leak. Engine vacuum is used to move the doors that control airflow for the heat and ac.
Aug 27, 2008 | 2000 Dodge Ram 1500 Truck
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
