Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The water despenser works but the icemaker doesn't
I have a kitchen aid superba. At first the water trickled out and the ice only made one or tube partial cubes at a time. Someone suggested to me to change the filter so I did that and now the water comes out fine but it is not making ANY ice. Does anyone have any suggestions. I am a ice chewer going nuts with no ice.
thanks
  • 22 Answers
The most popular problem area is the fill tube by the icemaker. Check for an ice build up inside of the tube. If that isn't the problem, you must ck the coils on the filter valve and the coils on the supply valve with an ohm meter. Check for kinked water lines, leaky water lines etc. An after thought, make sure that the icemaker itself hasn't got a huge bunch of ice it built up and can't dump out.
Posted on May 12, 2009
I hooked up my refrigerator and the ice maker is not working.it's a kitchen aid superba kscs251
First make sure your water valve is working . If so , look for fill tube that fills ice maker to be frozen. If it is frozen , unthaw tube. If its not then replace the ice maker.
May 31, 2013 | Refrigerators
I turned my water off when we left town for a month. After turning my water back on the ice maker has stopped working. Our refrigerator is a Kitchen-aid superba model and is approximately 4 - 5 years...
The issue is likely that the icemaker fill tube is frozen due to poor water pressure. You can use a turkey baster to thaw this tube which fills the icemaker. Make sure you use plenty of hot water because they often freeze back several inches!
Sep 11, 2010 | KitchenAid KSCS25FKSS Side by Side...
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
It appears that no water is getting to the ice maker in my kitchen aid superba side by side refrigerator. I know it is not a frozen water line because I still get filtered water through the door. Any...
selenoid valve to the icemaker can be malfunctioned.they can be found at the back side.
Generally icemaker water line is seperate then the water dispencer so it is possible that it is frozen.
Jun 30, 2009 | Refrigerators
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Jun 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
203 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
