Question about HP PSC 1610 All-In-One InkJet Printer
Instead of printing to paper, it wants to print (save) to a file
HP PSC 1600 will; not print to paper. It wants to fave to a file.
    Sergeant:
    Novelist:
  • 197 Answers
Make sure that you have it set as your default printer. You can do so through the printer section in your Control Panel.
Posted on May 12, 2009
MY HP PSC 1600 All-In-One says I'm out of paper. I am not out of paper and I have regular white paper in it as usuall. I have at least 15 sheets in the tray.I checked on the internet and it said to...
>> it would not catch the paper on the rollers so it could print.
Try more sheets of paper. After that, it's time to take it to a qualified printer technician, for professional trouble-shooting, tune-up (adjustment of those rollers), and maybe a proper burial in the responsibly-recycled bin.
Aug 19, 2011 | HP PSC 1600 InkJet Printer
I need to print from black ink instead of color. how do I do this on my 750 hp.
When you use word - go to file screen press print, next look for properties and click it, next look at top and click on paper/quality then select black and at botton select apply. Also if you select draft you save on ink.
Jun 14, 2011 | HP PSC 750 All-In-One InkJet Printer
When I try to copy or scan from the glass it tries to feed from the automatic feeder tray instead.
Make sure there's no paper in the tray.Use the printer control panel to scan.
First Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Second Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) or reversal.
If this not work reinstall the printer.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP PSC 1600 InkJet Printer
Can't print from computer
Reinstall the printer drivers. (completely remove the old ones first)
Try new drivers from HPs website if need be.
Check the print queue in control panel>printers to make sure nothing is lying in the print queue and blocking your printing.
Make sure that you are printing to the correct printer in the "print" dialogue box that pops up when you go file>print. Sometimes this can revert to "microsoft document printing" or somesuchand just save a file on your hard drive instead of printing (in techie speak, printing does not necessarily mean print out on a bit of paper). Or may the "Print" dialogue box wrongly is pointed at another/old printer that still has drivers installed on your pc when it pops up, check before clicking the "ok" button..
If not, try a new cable, if not, call HP.
Feb 05, 2010 | HP PSC 2175 All-In-One InkJet Printer
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Printing from the Net on my HP 1410-all-in-one
Make sure the "Print To File" checkbox is clear, on the printer selection dialog window.
Dec 28, 2008 | HP PSC 1410v All-in-One Printer
Printing color
no problem ,the printer settings got corrupted.just uninstall the printer drivers and then reinstall properly.it will be fine. thanks.
Dec 03, 2007 | HP PSC 1600 InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
