Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Loss of power when engaging deck
1538 sabre loss of power when engaging deck
    Champion:
  • 205 Answers
Check your compression. if you have a two cyl engine, start it and ground out each cyl (or pull off the plug) see if engine changes the rpms if one don't change check spark and compression on that side. if you only have one cyl go back to checking compression. get back to me with what you find. ps check your belts to mack sure nothing is in the pulleys like a stick and check under your deck to make sure you don't have a grass build up.
Posted on Oct 15, 2009
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sabre 17.542hs loss of power
you could have a weak coil and misfiring under a load each cylinder has it own coil on that engine you can get a inline spark tester to see
Sep 03, 2012 | John Deere Garden
Husqvarna YTH2242 lawn tractor loss of drive.
You can check the belt tention, between the deck and the chassis just to see if it is loose, it would reqire removing the deck to replace the belt.
Apr 18, 2017 | Husqvarna Garden
Power loss
sounds like the engine is running lean caused by dirty jets inside the carb
Aug 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Loss of Power when PTO is engaged
Something that the PTO drives is defective and placing excessive load on the engine.
May 18, 2017 | Garden
I have a 2000 Johne Deere Sabre 2046 HV and need a belt routing diagram and belt size
Hi Amy,
I also have a 46" Sabre deck and replaced my belt. The easiest way to describe is that the belt runs directly between the outer 2 blades across the back of the deck and threads through the front pulleys. Once I saw that detail, I was able to save a $40 belt install charge. Hope this helps someone. Cheers, Dean.
Oct 16, 2011 | Garden
I have a john deere sabre 15.5/42 and cant figure out how to put the deck belt back on
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Aug 28, 2009 | Garden
Loss of power when mower engaged
this is usually caused by a dirty restricted fuel filter as the engine has more demand put it with the deck engaged change filter and install with the arrow pointing to the carb
Jun 29, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
197 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
