Question about Refrigerators
I have a 2003 Kenmore full fridge and the door will not close correctly. When closed, the hinge is on the left, the bottom right lower side and corner are about 1 full centimeter from being sealed. There is a gap and I am not sure how to correct it. It seems like the door may have warpped.
  • dwpetker May 12, 2009
    Thanks for that. I went and checked all that and it seems to be all in the right places. I even took it all right out and tried to close the door, no difference. I notice the moulding has a crack in it running for about a foot up and down along the side of it about half way up the door. Would new moulding make a difference.
    When the door is closed the top of the door is 7/8th of an inch away from the fridge, the bottom of the door is1 and 1/8th away from the fridge in the closed position and hence the gap at the bottom of the door
  • dwpetker May 19, 2009
    Thanks very much for your help and ideas. Much apreciated. I have now ordered a new gasket. Thanks again for your great help and ideas.
    Sergeant:
    Champion:
  • 214 Answers
The first thing you need to cheak is if your crisper shelf is in place at the bottom .At times it will pop out or if you clean your crispers you put it back wrong.And the crisper will push at the bootom of the door causing it to not seal properly hope i helped:)
Posted on May 12, 2009
  • tom wright
    tom wright May 12, 2009
    Another thing you can try is losen the top hinge screws and then move the door around till it is straight and if that does not work try a hair dryer but be carfull that you do not melt it hold it far enough so it will not get to hot..Also cheak on the insaide part of door gaskit and see if there are screw there if so losen them all and then close the door and see if the inner door liner pushes your gaskit inplace Then carefully open the door and tighten them all back up Note do not remove the screws around gaskit just losen.Hope this helps if not you would need a new gaskit.Just give your local appliance parts place a call and give then your model # that is located on the top left insiade the fridge
  • tom wright
    tom wright May 19, 2009
    you are welcome always a great feeling to help :)
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
Left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Jan 24, 2015 | KitchenAid Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
Hello, my fridge door is off kilter. I can see that is starting not to seal properly with the box. We've removed as much weight as we can off of the door. I've also tried to slide a shim underneath the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Feb 27, 2010 | Refrigerators
Bottom Door doesn't close right.
heck level of your fridg and check the hinges of the door
Dec 29, 2009 | Kenmore Refrigerators
How do you adjust the doors to closed completely?
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
