Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Replacing the thermostat on LSE7806 dryer
I took off the little panels on the back hoping I could see the thermostat to replace it, but I guess it will not be that easy.  I gather I have to take off the back cabinet.  It looks like the back and sides are one piece.  Can i take this back/side piece off withour taking off the front?  Do i take out all the screws on the back and top front to get the cabinet off?  Can you tell me how the cabinet comes off?
The front panel has two screws to take if off.  You do not access fromt he back or top.
Posted on Oct 19, 2007
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
Kenmore electric dryer model 42890 wont heat up or stay running, is it thermister
Dryers need airflow to work properly.
Unplug the unit and pull away from wall. Use flashlight, gloves, etc. as neccessary to inspect ducting for dryer lint. Remove any and all lint. Use a shop vac to clean vents and area. You might also need to use the shop vac to vaccuum out or blow out ducting.
Another typical solution is to replace the two thermostat controllers.
Parts available from Sears parts online for around $20 each.
Unplug Dryer and remove back panel from unit (8-10 screws.) A Simple pair of pliers will do the trick. Use shop vac to remove any and all dryer lint from inside unit. Thermostats look to be central right and easily accessible.
I am not a professional by any means, but I was a mechanical engineer on a nuclear submarine's reactor plant and I did work for 6 months installing and light repair on Maytag appliances.
I have seen several websites with info that supports the problem being the thermostats. My guess is that I would treat this like replacing headlights for your car. Never replace just one, because the older one will not be as bright and will most likely fail in the near future. For the low cost and high effort to go back and replace a second thermostat...you might as well replace both at the same time.
Dec 30, 2010 | Dryers
Dryer won't start, not the door switch ,not the panel switch, not at the breaker?
Dec 30, 2010 | Kenmore 500 6952 Dryer
The squirl cage on the dryer of my model LSE7806
Howdy,
Absolutely should be positively "locked" to the motor shaft. There should be a set screw in the collar of the squirrel cage mount. Either it is missing of has loosened. Please tighten (or replace) this set screw. Also, it is very IMPORTANT to make sure that if there is a flat machined surface on the motor shaft, that you align the squirrel cage (and set screw) so that the set screw will seat firmly and squarely against this flat surface. This design ensures that once properly aligned and set, that the squirrel cage will follow the motor shaft faithfully. Also, it is recommmended to apply some thread sealant (Locktite) to the threads of the set screw so this will not happen in the future. Vibration can be the cause of this.
Good luck,
J
Oct 20, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer run won't heat up took off back panel don't know which tube contain element. if that not the problem don't know where to locate thermal fuse i need pictures diagram illustration
Hi, if this is an electric dryer and is a whirlpool model, the element is located in a housing on the right side (looking at the back)
You can run the dryer and check with voltage meter to see if it is getting 240V. If there is voltage, replace the element. If there is not voltage, check the thermostats and the fuse for continuity. If they do not have continuity, replace them.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Whirlpool electric dryer not heating
I had the same problem today. After stumbling through the schematics (they were taped up behind the main control panel on top of the dryer) and ohming out a bunch of different parts with my multimeter, I finally took the heater element out and found that it had burned in two in a spot (I could see it once I took the element off of the dryer). I replaced it for about $80. The guy at the parts store said that is usually caused by a clogged vent, which is probably the case for mine, since my vent is poorly designed. I hope this helps someone.
Nov 07, 2008 | Whirlpool LEB6300 Electric Dryer
Dryer wont heat
hi jimenez0512 this could be 1 of 2 problems 1 the heater element is down would need replacing 2 the lower heater element is down needs replacing which is the likelist problem it will be the first thermostat to the left should have a little ink dot on it when u buy the new thermostat kit it will come with both replace both u will only have to replace the higher stat within 2months anyway. Now if the thermostat has a little button on it press it and it should re-start the stat these are at the back of the dryer behind a shaped panel let me know how u go m8 peter
Jun 02, 2008 | GE DBXR463EBWW Electric Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
