Question about IBM E74 17" CRT Monitor
Light line in monitor screen
I saw a line in the screen of my monitor everytime i open it. What do you think is the problem of my monitor? Please give me some instruction on how to solve it. Thanks!!
    Problem Solver:
  • 4 Answers
Ibm e74 contrast low
Posted on Jul 31, 2009
  • 180 Answers
It may be due to the screen high screen voltage . You can correct it by adjusting screen control on the flyback transformer .
Posted on May 12, 2009
Hello! I've been using my Compaq Presario (2200) Laptop for 5 years now, then all of a sudden I saw 2 vertical lines on the screen. both the lines are clear red line , one located about 1/3 from the...
its the lifetime getting over of the lcd display , either get it replaced or just ignore it . Nothing of repairment can be applied to it . I am an authorised repairer for Compaq at my region . Sorry that we coudnt help you sir ,
Thankyou , please vote for me .
Jun 05, 2011 | Compaq Presario M2000 Notebook
Just recently the monitor started experiencing a faded screen and vertical lines1/8" spaced across the screen. A remote controller took over my computer and saw what i saw and mentioned something...
Greetings,
You can double check the suggestion of the vidoe card by connecting your computer to another monitor. If the lines appear on the second monitor then the diagnosis is correct and the video card in your computer is failing. If the lines do not appear in the second monitor, then your monitor's screen is failing and you'll need a new monitor.
Regards,
Selk
Nov 16, 2010 | Gateway HD2200 LCD Monitor
Lid got slammed once and opened it and saw some lines and then nothing. Everything else seems to work I think but I couldn't get it to work with an external flat screen monitor. I have taken it all apart...
> couldn't get it to work with an external ... monitor
With the computer turned-off, connect the monitor to the SVGA port.
Turn the computer on -- the usual "start-up" messages should flash on the LCD screen.
Or, take the laptop into a darkened room, to see if the usual Windows "desktop" icons & wallpaper are dimly visible.
Or, take the laptop & the power-supply to a qualified technician, for professional trouble-shooting.
Sep 26, 2010 | Sony VAIO PCG-R505 12.1 in. Flat Panel LCD...
Memory recall option is Continuosly blinking on the screen and also brightness option also too..what to do with this problem
This is the exact same problem which I am facing at this moment. I opened the Case of the monitor. I saw that there are 2 small buttons with a extended rod attached which goes into the buttons on the Monitors body. I saw the Contrast button and the brightness and the Menu button are stuck. I also saw that the monitor pads and the monitor sensor board has complete rust. I think I have to change the button pads and the Monitor Board. The same thing I am seeing in your case. I think this is a cause of Excessive moisture content in the air which is causing rust and jamming of Buttons.
I think now you can get what to do.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
Vertical lines in my laptop screen
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
Monitor vertical lines
Dear Choji,
If obviously the problem has not occured again then you have solved it on your own. Bravo to that. You shoud give yourself a proud pat on your back. But if the problem still exists, then its with the device driver settings of the monitor. Try reinstalling the monitor by reinstalling its drivers.
If this still does not help then refer to an authoised service personel.
Mar 19, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
A follow-up on my Dell vertical lines issues
I understand that it seems odd that sometimes they disappear.
I have a vertical line on one of my laptops right now that it takes about 3 seconds before it appears on the screen but once it's there. It's there.
I think it has to "warm up" before it comes back.
I used to do Technical support for a company that produced computers with 5inch wide screens, and everytime something with a line was mentioned, "Fix display cable" was the reason.
Because everytime you pushed the screen up to see the keyboard the line disappeared (because the display cable moved) But I digress.
All I'm certain of is that if you change the display cable this will be fixed.
Mar 15, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
LCD... Problem
so I have the same problem. when you get the answer please send me an email with the info. I´ll do the same
uguetoe@gmail.com
Nov 25, 2007 | Gateway FPD1975 19" LCD Monitor
Thin pale Horizontal line
I tried this and it has worked temporarily by banging the monitor not great but it did work, no tech knowledge if there is any other advise please email.
Hiyama Monitor Model: Vision Master 17 (8617E Chassis)
Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
(John)
Aug 20, 2007 | Gateway FPD1975 19" LCD Monitor
Vertical colored lines
I had the same problem with my monitor, saw only coloured vertical lines. I opened it, opened the back of the metal casing to get access to the circuits. There I found a loose connector. I reset it and it worked again!
Aug 06, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
IBM E74 17" CRT Monitor Logo
184 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
