Question about Ryobi Backpack Blower 25.4cc
Ryobi RY08576 25.4cc was started without mixed fuel
New Ryobi RY08576 25.4cc backpack leaf blower was started without mixed fuel. What parts will need replacing? Engine is not locked up but will not start
  • 1 more comment
  • Samuel Charles Spriggs May 11, 2010
    Impossible to know without taking engine apart.
    Does it make popping noises when you crank it?
  • Anonymous Mar 23, 2014
    Not started in awhile
  • Anonymous Mar 26, 2014
    Black leaf blower 2005 Mosley stock came out of crankshaft need to se a picture or diagram of it
    President:
  • 272 Answers
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
My backpack leaf blower wont star. It was working fine yesterday now it wont star at all. Any suggestions?
Hi! Look for the spark plug,take it out and replace it with a new one,and then try to start it up.Also check if you have fuel and oil mixture right.
It is the most common failure in such hardware.Good luck!
Mar 06, 2011 | Ryobi Backpack Blower 25.4cc
What is the gas oil ratio of the ryobi leaf blower
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Nov 30, 2010 | Ryobi Backpack Blower 25.4cc
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
RYOBI BACKPACK CRANKS BUT SHUTS OFF AFTER RUNNING ABOUT 10 MINUTES
Make sure you running gas/oil mix in it and you dont have too much oil. It may also need a carb cleaning/adjustment
Nov 10, 2009 | Ryobi Backpack Blower 25.4cc
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
MODEL RYO9600 LEAF PULLSTART BLOWER MISSING FLEX HOSE TO WAND
Go to this link for the Ryobi parts. You can get one for less than $5.
http://www.ereplacementparts.com/ryobihm-ry09600-backpack-blower-parts-c-7931_15636_130605.html
Oct 17, 2009 | Ryobi Garden
Backpack only runs low RPM, especially when cold.
Your carbeurator is gummed up. Remove the old fuel and make up a new fuel mix with new gas from the gas station. Then get a can of carbeurator cleaner spray. Three short squirts in the air intake and let it run. Three more squirts every minute or so until you dissolve the partial blockage that is causing your problem.
Jul 28, 2009 | Ryobi Backpack Blower 25.4cc
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower 25.4cc Logo
844 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
